주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung ST700 Battery Replacement
    1. Samsung ST700 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • The battery is located on the bottom of the camera underneath a latch door
      • To open the latched door, move the latch (circled in the picture) toward the center of the camera, and the door should pop open.
      댓글 쓰기
    2. Samsung ST700 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • When the bottom componets are exposed, the battery is held by a blue latch. (Blue latch is circled in the picture)
      • Push the blue latch latch to relase the battery from its slot. It should be pushed out.
      • Remove the battery.
      • Move the blue latch to put in the new battery.
      • Make sure that the battery is going in the correct way. The three golden slits should be matching up with three golden prongs on the bottom of the battery holder.
      • Close the latch door over the components and move the latch toward the side of the camera. Trying turning on the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tanner Studley
회원 가입일: 03/04/16
149 평판
안내서 1개를 작성함
UMass Dartmouth, Team 6-4, Bhusal Spring 2016 UMass Dartmouth, Team 6-4, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G4
3 회원들
안내서 1개 작성
1가이드 댓글
my baterry inflated with air and now is stuck in the slot, what should i do?
Denix 54 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 45
전체 시간: 1,128
