주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Stratosphere Flex Cable Replacement
필요한 것
  1. Samsung Stratosphere Flex Cable Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
    댓글 쓰기
  2. Samsung Stratosphere Flex Cable Replacement: 2 단계, 이미지 1개 중 1개
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
    댓글 쓰기
  3. Samsung Stratosphere Flex Cable Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
    댓글 쓰기
  4. Samsung Stratosphere Flex Cable Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
    댓글 쓰기
  5. Samsung Stratosphere Flex Cable Replacement: 5 단계, 이미지 1개 중 1개
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
    댓글 쓰기
  6. Samsung Stratosphere Flex Cable Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    댓글 쓰기
  7. Samsung Stratosphere Flex Cable Replacement: 7 단계, 이미지 2개 중 1개 Samsung Stratosphere Flex Cable Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
    댓글 쓰기
  8. Samsung Stratosphere Flex Cable Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
    댓글 쓰기
  9. Samsung Stratosphere Flex Cable Replacement, Front Camera: 9 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
    • Pry the keyboard away from the casing with the plastic opening tool.
    • The keyboard should come off with almost no force at all.
    댓글 쓰기
  10. Samsung Stratosphere Flex Cable Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
    댓글 쓰기
  11. Samsung Stratosphere Flex Cable Replacement: 11 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to carefully loosen the golden metal plate.
    • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
    댓글 쓰기
  12. Samsung Stratosphere Flex Cable Replacement: 12 단계, 이미지 1개 중 1개
    • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
    • Carefully take off the keyboard casing with your fingers.
    • The golden metal plate should fit through the wide slot of the casing.
    댓글 쓰기
  13. Samsung Stratosphere Flex Cable Replacement: 13 단계, 이미지 1개 중 1개
    • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
    • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
    댓글 쓰기
  14. Samsung Stratosphere Flex Cable Replacement: 14 단계, 이미지 1개 중 1개
    • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
    댓글 쓰기
  15. Samsung Stratosphere Flex Cable Replacement: 15 단계, 이미지 2개 중 1개 Samsung Stratosphere Flex Cable Replacement: 15 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the groove at the top of the rear panel.
    • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
    • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
    댓글 쓰기
  16. Samsung Stratosphere Flex Cable Replacement: 16 단계, 이미지 1개 중 1개
    • Lift the flex cable and position it so the part containing the metal plate can come free.
    • Pull the part containing the metal plate away from the rest of the rear panel.
    댓글 쓰기
  17. Samsung Stratosphere Flex Cable Replacement: 17 단계, 이미지 2개 중 1개 Samsung Stratosphere Flex Cable Replacement: 17 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to loosen the front-facing camera from the plastic casing.
    • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
    댓글 쓰기
  18. Samsung Stratosphere Flex Cable Replacement, Flex Cable: 18 단계, 이미지 1개 중 1개
    • Carefully peel the blue tape from the bottom of the flex cable and set it aside.
    댓글 쓰기
  19. Samsung Stratosphere Flex Cable Replacement: 19 단계, 이미지 2개 중 1개 Samsung Stratosphere Flex Cable Replacement: 19 단계, 이미지 2개 중 2개
    • Use one of the plastic opening tools to loosen the flex cable from its central housing.
    • Pull lightly on the flex cable to free it from the housing.
    • The cable may audibly snap as it is freed from its attachment.
    댓글 쓰기
  20. Samsung Stratosphere Flex Cable Replacement: 20 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to loosen the flex cable and speaker from the bottom of the phone.
    • Pull upward with the tweezers and the flex cable will come loose.
    • The flex cable will come free with the front-facing camera attached. In order to remove the front-facing camera, see our guide here.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jonathan Oyan
회원 가입일: 10/18/13
624 평판
안내서 1개를 작성함
Cal Poly, Team 11-32, Amido Fall 2013 Cal Poly, Team 11-32, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G32
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 15
지난 30일: 50
전체 시간: 1,665
