주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Stratosphere Rear Camera Replacement
필요한 것
  1. Samsung Stratosphere Rear Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
    댓글 쓰기
  2. Samsung Stratosphere Rear Camera Replacement: 2 단계, 이미지 1개 중 1개
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
    댓글 쓰기
  3. Samsung Stratosphere Rear Camera Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
    댓글 쓰기
  4. Samsung Stratosphere Rear Camera Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
    댓글 쓰기
  5. Samsung Stratosphere Rear Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
    댓글 쓰기
  6. Samsung Stratosphere Rear Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    댓글 쓰기
  7. Samsung Stratosphere Rear Camera Replacement: 7 단계, 이미지 2개 중 1개 Samsung Stratosphere Rear Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
    댓글 쓰기
  8. Samsung Stratosphere Rear Camera Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
    댓글 쓰기
  9. Samsung Stratosphere Rear Camera Replacement, Rear Camera: 9 단계, 이미지 1개 중 1개
    • Gently pull the camera to the left while keeping it as close to the motherboard as possible.
    • The metal foil connector attached to the camera should slide out of the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ryan
회원 가입일: 10/20/13
375 평판
안내서 2개를 작성함
Cal Poly, Team 11-32, Amido Fall 2013 Cal Poly, Team 11-32, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G32
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 31
전체 시간: 969
