주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung TL220 Battery Spring Replacement
필요한 것
  1. Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: 1 단계, 이미지 2개 중 1개 Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: 1 단계, 이미지 2개 중 2개
    • Begin by unscrewing all seven 4 mm phillip's screws located on the outside of the camera.
    • Using the plastic opening tool carefully pry open the camera, lifting the back casing off.
    댓글 쓰기
  2. Samsung TL220 Battery Spring Replacement: 2 단계, 이미지 2개 중 1개 Samsung TL220 Battery Spring Replacement: 2 단계, 이미지 2개 중 2개
    • Now that you have the back casing off, gently move the LCD screen from the camera to the right and lay it facing down on the table.
    • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver.
    댓글 쓰기
  3. Samsung TL220 Battery Spring Replacement: 3 단계, 이미지 2개 중 1개 Samsung TL220 Battery Spring Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Unclip the four connectors with the plastic opening tool which holds down the orange film strips.
    • Gently with the tweezers remove the four orange film strips from the connectors.
    댓글 쓰기
  4. Samsung TL220 Battery Spring Replacement: 4 단계, 이미지 2개 중 1개 Samsung TL220 Battery Spring Replacement: 4 단계, 이미지 2개 중 2개
    • Once the orange film strips have been released from the connectors, unscrew the Phillips 4 mm silver screw which holds down the top of the camera's frame.
    • With your fingers gently push up the camera's top frame. Once the camera's top frame is off you can than gently remove the camera's front casing off, as well.
    댓글 쓰기
  5. Samsung TL220 Battery Spring Replacement: 5 단계, 이미지 2개 중 1개 Samsung TL220 Battery Spring Replacement: 5 단계, 이미지 2개 중 2개
    • Flip the entire camera over so that the lenses are facing upward with the LCD screen showing to the side.
    • Now remove the silver case, seen demonstrated in the picture.
    댓글 쓰기
  6. Samsung TL220 Battery Spring Replacement: 6 단계, 이미지 1개 중 1개
    • After all the parts are disassembled, you will reach the spring part of the camera.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
chelsa
회원 가입일: 03/03/15
358 평판
안내서 3개를 작성함
3 Tech Girls 3 Tech Girls 회원
Community
2 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 11
지난 30일: 30
전체 시간: 997
