주요 콘텐츠로 건너뛰기
Samsung TL220 Power Button Replacement
필요한 것
  1. Samsung TL220 Power Button Replacement, Power Button: 1 단계, 이미지 3개 중 1개 Samsung TL220 Power Button Replacement, Power Button: 1 단계, 이미지 3개 중 2개 Samsung TL220 Power Button Replacement, Power Button: 1 단계, 이미지 3개 중 3개
    • Check for debris and dust around the power button to make sure it's clean.
    • If dust is absent, then begin with unscrewing the seven outside shell 4 mm Philips screws with the Philips screw driver.
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
  2. Samsung TL220 Power Button Replacement: 2 단계, 이미지 2개 중 1개 Samsung TL220 Power Button Replacement: 2 단계, 이미지 2개 중 2개
    • Now that you have the back casing off, gently remove the LCD screen from the camera.
    • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver(See image).
  3. Samsung TL220 Power Button Replacement: 3 단계, 이미지 2개 중 1개 Samsung TL220 Power Button Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Unclip the four connecters that hold down the orange copper film strips with the plastic opening tool.
    • Then carefully pull out the three film strips with the ifixit tweezers.
  4. Samsung TL220 Power Button Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 4 mm Philip screw located above the center film strip with the Philips screw driver. This will allow the top frame to come loose to take off.
  5. Samsung TL220 Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Then pull back the black claw located at the bottom right of the camera, to the right with the plastic opening tool. This holds the main plate down.
  6. Samsung TL220 Power Button Replacement: 6 단계, 이미지 1개 중 1개
    • Slowly lift with your fingers, the top frame of the camera to get to the power button.
  7. Samsung TL220 Power Button Replacement: 7 단계, 이미지 1개 중 1개
    • Replace power button with new one.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
chelsa
회원 가입일: 03/03/15
358 평판
안내서 3개를 작성함
3 Tech Girls 3 Tech Girls 회원
Community
2 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 374
