주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung WB2200F Flash Option Button Replacement
필요한 것
    1. Samsung WB2200F Flash Option Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Place the camera upside down on a hard surface such as a table. Make sure that the battery compartment is visible.
      댓글 쓰기
    2. Samsung WB2200F Flash Option Button Replacement: 2 단계, 이미지 1개 중 1개
      • Twist the nob counter-clockwise while pushing cover to the left. Then pull the cover up to reveal the battery.
      댓글 쓰기
    3. Samsung WB2200F Flash Option Button Replacement: 3 단계, 이미지 1개 중 1개
      • Slide the blue tab to the right to release the battery.
      댓글 쓰기
    4. Samsung WB2200F Flash Option Button Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully slide the battery out of the camera. It can then be replaced with a new battery.
      댓글 쓰기
    1. Samsung WB2200F Flash Option Button Replacement, Face-plate: 5 단계, 이미지 3개 중 1개 Samsung WB2200F Flash Option Button Replacement, Face-plate: 5 단계, 이미지 3개 중 2개 Samsung WB2200F Flash Option Button Replacement, Face-plate: 5 단계, 이미지 3개 중 3개
      • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
      댓글 쓰기
    2. Samsung WB2200F Flash Option Button Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
      댓글 쓰기
    3. Samsung WB2200F Flash Option Button Replacement: 7 단계, 이미지 1개 중 1개
      • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
      • Make sure to not damage any of the electronic components of the camera
      댓글 쓰기
    1. Samsung WB2200F Flash Option Button Replacement, Flash Option Button: 8 단계, 이미지 1개 중 1개
      • Looking at the back of the exposed face plate, remove the four 5mm screws, that hold down the metal cover, using the screw driver with the JIS size 000 head.
      댓글 쓰기
    2. Samsung WB2200F Flash Option Button Replacement: 9 단계, 이미지 1개 중 1개
      • Gently lift off the metal cover.
      댓글 쓰기
    3. Samsung WB2200F Flash Option Button Replacement: 10 단계, 이미지 1개 중 1개
      • Clean out any dust or debris from the button interface.
      • Replace faulty button.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Rachelle
회원 가입일: 03/08/16
213 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-4, Landers Spring 2016 UMass Dartmouth, Team 5-4, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 33
전체 시간: 579
