주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung WB350F Screen Replacement
필요한 것
    1. Samsung WB350F Screen Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Samsung WB350F Screen Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Samsung WB350F Screen Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
      • Remove the wristlet strap.
      • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
      댓글 쓰기
    2. Samsung WB350F Screen Replacement: 2 단계, 이미지 3개 중 1개 Samsung WB350F Screen Replacement: 2 단계, 이미지 3개 중 2개 Samsung WB350F Screen Replacement: 2 단계, 이미지 3개 중 3개
      • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
      • There is one silver screw on the bottom and two black screws on each side.
      • Keep the screws together for an easier re-assembly later.
      댓글 쓰기
    3. Samsung WB350F Screen Replacement: 3 단계, 이미지 3개 중 1개 Samsung WB350F Screen Replacement: 3 단계, 이미지 3개 중 2개 Samsung WB350F Screen Replacement: 3 단계, 이미지 3개 중 3개
      • Open the case of the camera using your plastic opening tool.
      • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
      • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
      댓글 쓰기
    4. Samsung WB350F Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the plastic casing, exposing the inner workings of the camera.
      댓글 쓰기
    1. Samsung WB350F Screen Replacement, Screen: 5 단계, 이미지 2개 중 1개 Samsung WB350F Screen Replacement, Screen: 5 단계, 이미지 2개 중 2개
      • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
      • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
      댓글 쓰기
    2. Samsung WB350F Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Move the menu button panel to the right as well as the screen.
      • Be careful because each are connected to the camera by a ribbon.
      댓글 쓰기
    3. Samsung WB350F Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
      댓글 쓰기
    4. Samsung WB350F Screen Replacement: 8 단계, 이미지 2개 중 1개 Samsung WB350F Screen Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the silver panel.
      댓글 쓰기
    5. Samsung WB350F Screen Replacement: 9 단계, 이미지 2개 중 1개 Samsung WB350F Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Flip the screen back over.
      • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
      댓글 쓰기
    6. Samsung WB350F Screen Replacement: 10 단계, 이미지 2개 중 1개 Samsung WB350F Screen Replacement: 10 단계, 이미지 2개 중 2개
      • Carefully detach both ribbons by gently pulling one at a time.
      • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
      • Be sure to pull gently as you do not want to break either ribbon.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Casey Bernier
회원 가입일: 03/04/16
131 평판
안내서 1개를 작성함
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G2
4 회원들
안내서 8개를 작성함
1가이드 댓글
Broke my screen, bought a new one on the internet (ebay) and used this tutorial for replacement.
Good photos and every step is clear to follow
Gerald Heidrich - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 51
전체 시간: 2,294
