주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Watch Active Sensor Array Replacement
필요한 것
    1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: 1 단계, 이미지 2개 중 1개 Samsung Watch Active Sensor Array Replacement, Turn off the watch: 1 단계, 이미지 2개 중 2개
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      댓글 쓰기
    2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: 2 단계, 이미지 1개 중 1개
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      댓글 쓰기
    3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 1개 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 2개 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 3개
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      댓글 쓰기
    4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 1개 Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 2개
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      댓글 쓰기
    5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: 5 단계, 이미지 1개 중 1개
      • Remove the back cover.
      댓글 쓰기
    1. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: 6 단계, 이미지 3개 중 1개 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: 6 단계, 이미지 3개 중 2개 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: 6 단계, 이미지 3개 중 3개
      • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
      • Carefully twist the opening pick to separate the sensor array from the back cover.
      댓글 쓰기
    2. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: 7 단계, 이미지 2개 중 1개 Samsung Watch Active Sensor Array Replacement, Remove the sensor array: 7 단계, 이미지 2개 중 2개
      • Remove the sensor array from the back cover.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
134,897 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,589개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 65
전체 시간: 4,936
