주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sansa e260R Memory Board Replacement
필요한 것
    1. Sansa e260R Memory Board Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
      • Before disassembling the device, make sure it is powered off.
      • Remove the four 1.5mm screws on the back of the device.
      댓글 쓰기
    2. Sansa e260R Memory Board Replacement: 2 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, lift the metal backing from the front of the device.
      댓글 쓰기
    3. Sansa e260R Memory Board Replacement: 3 단계, 이미지 1개 중 1개
      • Pull the rear panel off of the Sansa e260R.
      댓글 쓰기
    1. Sansa e260R Memory Board Replacement, Battery: 4 단계, 이미지 1개 중 1개
      • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
      댓글 쓰기
    1. Sansa e260R Memory Board Replacement, Front Panel: 5 단계, 이미지 1개 중 1개
      • Remove the four 1.5mm screws on the inner casing of the device.
      • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
      댓글 쓰기
    2. Sansa e260R Memory Board Replacement: 6 단계, 이미지 1개 중 1개
      • Flip the device so that the front is facing you.
      • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
      댓글 쓰기
    3. Sansa e260R Memory Board Replacement: 7 단계, 이미지 2개 중 1개 Sansa e260R Memory Board Replacement: 7 단계, 이미지 2개 중 2개
      • Pull the front cover away from the rest of the device.
      댓글 쓰기
    1. Sansa e260R Memory Board Replacement, Memory Board: 8 단계, 이미지 2개 중 1개 Sansa e260R Memory Board Replacement, Memory Board: 8 단계, 이미지 2개 중 2개
      • Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
      • Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
      댓글 쓰기
    2. Sansa e260R Memory Board Replacement: 9 단계, 이미지 1개 중 1개
      • Pull the bottom of the motherboard up and then out.
      댓글 쓰기
    3. Sansa e260R Memory Board Replacement: 10 단계, 이미지 1개 중 1개
      • On the back of the motherboard, there is a rectangle of rubber.
      • Peel the rectangle off slowly.
      댓글 쓰기
    4. Sansa e260R Memory Board Replacement: 11 단계, 이미지 1개 중 1개
      • Under the rubber rectangle, there is a strip of black tape.
      • Peel the tape off about halfway so that it is no longer attached to the memory board.
      댓글 쓰기
    5. Sansa e260R Memory Board Replacement: 12 단계, 이미지 1개 중 1개
      • Carefully peel the memory board away from the rest of the motherboard
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
JenniferW
회원 가입일: 01/31/12
194 평판
안내서 2개를 작성함
Cal Poly, Team 8-15, Maness Winter 2012 Cal Poly, Team 8-15, Maness Winter 2012 회원
CPSU-MANESS-W12S8G15
5 회원들
안내서 15개를 작성함
1가이드 댓글
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
Admin User - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 41
전체 시간: 3,106
