주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sanyo VPC S1275 LCD Screen Replacement
필요한 것
    1. Sanyo VPC S1275 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Place your thumb on the right side of the camera over the battery door.
      • Slide the battery door to the right until the door lifts up.
      댓글 쓰기
    2. Sanyo VPC S1275 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Remove and recycle old batteries.
      댓글 쓰기
    1. Sanyo VPC S1275 LCD Screen Replacement, Case: 3 단계, 이미지 3개 중 1개 Sanyo VPC S1275 LCD Screen Replacement, Case: 3 단계, 이미지 3개 중 2개 Sanyo VPC S1275 LCD Screen Replacement, Case: 3 단계, 이미지 3개 중 3개
      • Remove the following six screws using the Phillips #00 screwdriver:
      • Two screws on the left side of the camera.
      • Two screws on the right side of the camera.
      • Two screws on the bottom of the camera.
      댓글 쓰기
    2. Sanyo VPC S1275 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Sanyo VPC S1275 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
      • Open the battery slot on the bottom of the camera by sliding the door to the right.
      • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
      댓글 쓰기
    3. Sanyo VPC S1275 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Sanyo VPC S1275 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Sanyo VPC S1275 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
      • Insert a spudger in the seam at the bottom of the camera.
      • Gently separate the rear case from the front of the camera.
      댓글 쓰기
    4. Sanyo VPC S1275 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • This step is only needed for the case and logic board replacement
      • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
      댓글 쓰기
    5. Sanyo VPC S1275 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
      • This step is only needed for the case replacement.
      • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
      • Slide the battery door off of the hinge.
      댓글 쓰기
    1. Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 1개 Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 2개
      • Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
      • Place the LCD screen on a non-abrasive surface.
      댓글 쓰기
    2. Sanyo VPC S1275 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Using the spudger lift the black flap up to release the ribbon cable.
      • The LCD screen will now be completely detached from the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Evan Perez
회원 가입일: 04/15/10
19 평판
안내서 2개를 작성함
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010 회원
CPSU-REGAN-S10S24G24
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 51
전체 시간: 3,699
