주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sanyo VPC-T850 Lens Replacement
필요한 것
    1. Sanyo VPC-T850 Lens Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
      댓글 쓰기
    2. Sanyo VPC-T850 Lens Replacement: 2 단계, 이미지 1개 중 1개
      • Locate the hatch found on the bottom of the camera.
      • Open the hatch by gripping the small notch and sliding it outwards.
      댓글 쓰기
    3. Sanyo VPC-T850 Lens Replacement: 3 단계, 이미지 1개 중 1개
      • Push the small, plastic arm out of the way to free the battery.
      • The battery is spring loaded and will pop out slightly when the arm is moved.
      댓글 쓰기
    4. Sanyo VPC-T850 Lens Replacement: 4 단계, 이미지 1개 중 1개
      • Pull the battery out of the camera and close the hatch.
      • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
      댓글 쓰기
    1. Sanyo VPC-T850 Lens Replacement, Outer Casing: 5 단계, 이미지 3개 중 1개 Sanyo VPC-T850 Lens Replacement, Outer Casing: 5 단계, 이미지 3개 중 2개 Sanyo VPC-T850 Lens Replacement, Outer Casing: 5 단계, 이미지 3개 중 3개
      • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
      • Be sure to keep track of the side each screw comes from, as they come in different lengths.
      댓글 쓰기
    2. Sanyo VPC-T850 Lens Replacement: 6 단계, 이미지 2개 중 1개 Sanyo VPC-T850 Lens Replacement: 6 단계, 이미지 2개 중 2개
      • Orient the camera so the display is facing up.
      • Gently pull off the rear panel surrounding the display.
      • There are still three green wires connecting the panel to the rest of the camera.
      • Use your prying tool if you have difficulties removing the panel by hand.
      댓글 쓰기
    3. Sanyo VPC-T850 Lens Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the eight black screws connecting the keypad circuit board to the rear panel.
      댓글 쓰기
    4. Sanyo VPC-T850 Lens Replacement: 8 단계, 이미지 2개 중 1개 Sanyo VPC-T850 Lens Replacement: 8 단계, 이미지 2개 중 2개
      • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
      댓글 쓰기
    5. Sanyo VPC-T850 Lens Replacement: 9 단계, 이미지 1개 중 1개
      • Flip the camera over so the lens is facing up.
      • Gently lift up the front panel to remove it from the rest of the camera.
      • Use your plastic opening tool if you have difficulties removing the panel by hand.
      댓글 쓰기
    1. Sanyo VPC-T850 Lens Replacement, LCD Display: 10 단계, 이미지 1개 중 1개
      • Flip the device over to where the display is located.
      • Using your plastic opening tool, lift the display out of its metal housing.
      댓글 쓰기
    2. Sanyo VPC-T850 Lens Replacement: 11 단계, 이미지 1개 중 1개
      • Locate the orange ribbon connecting the display to the camera.
      • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
      댓글 쓰기
    3. Sanyo VPC-T850 Lens Replacement: 12 단계, 이미지 1개 중 1개
      • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
      • Pull slowly to avoid severing the orange ribbon from the display.
      댓글 쓰기
    1. Sanyo VPC-T850 Lens Replacement, Lens: 13 단계, 이미지 1개 중 1개
      • Orient the camera so the lens is facing up.
      • Locate and remove the two screws connecting the lens to the camera.
      댓글 쓰기
    2. Sanyo VPC-T850 Lens Replacement: 14 단계, 이미지 2개 중 1개 Sanyo VPC-T850 Lens Replacement: 14 단계, 이미지 2개 중 2개
      • Flip the camera back around to the other side.
      • Remove the four black screws connecting the metal display holder to the camera.
      • You do not have to remove the three screws located near the center.
      • Gently lift the display holder to reveal the underside of the lens.
      댓글 쓰기
    3. Sanyo VPC-T850 Lens Replacement: 15 단계, 이미지 3개 중 1개 Sanyo VPC-T850 Lens Replacement: 15 단계, 이미지 3개 중 2개 Sanyo VPC-T850 Lens Replacement: 15 단계, 이미지 3개 중 3개
      • Locate where the larger orange ribbon is plugged into the motherboard.
      • There should be a rectangular foam piece covering the part it is plugged into.
      • Using your plastic opening tool, gently lift the edge of the rectangle where the orange ribbon is connected.
      댓글 쓰기
    4. Sanyo VPC-T850 Lens Replacement: 16 단계, 이미지 1개 중 1개
      • With two fingers, slowly lift the lens out of its compartment.
      댓글 쓰기
    5. Sanyo VPC-T850 Lens Replacement: 17 단계, 이미지 1개 중 1개
      • With the lens between your thumb and index finger, pull to delicately slide the ribbons out of their connections.
      • The lens should be placed back into the compartment before attempting to reconnect the ribbons.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
James Robinson
회원 가입일: 10/27/15
459 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 44
전체 시간: 843
