주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Scanner Head Replacement
필요한 것
    1. Scanner Head Replacement, Remove Back Panel: 1 단계, 이미지 1개 중 1개
      • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
      댓글 쓰기
    2. Scanner Head Replacement, Remove Inner Back Pannel: 2 단계, 이미지 2개 중 1개 Scanner Head Replacement, Remove Inner Back Pannel: 2 단계, 이미지 2개 중 2개
      • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
      댓글 쓰기
    3. Scanner Head Replacement, Remove Upper Portion: 3 단계, 이미지 2개 중 1개 Scanner Head Replacement, Remove Upper Portion: 3 단계, 이미지 2개 중 2개
      • Press down on the two plastic hinges to remove the upper portion of printer.
      댓글 쓰기
    4. Scanner Head Replacement, Unplug Speaker Wire: 4 단계, 이미지 1개 중 1개
      • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
      댓글 쓰기
    5. Scanner Head Replacement, Removing Scanner Tray: 5 단계, 이미지 2개 중 1개 Scanner Head Replacement, Removing Scanner Tray: 5 단계, 이미지 2개 중 2개
      • Rotate the printer so the paper tray is facing towards you.
      • Gently lift the scanner tray up and away from the printer.
      • Press the gray plastic tabs inward to release the tabs from the printer.
      댓글 쓰기
    6. Scanner Head Replacement, Removing Scanner Tray - cont.: 6 단계, 이미지 1개 중 1개
      • Returning to the back of the printer, remove the scanner from the back hinges.
      • With pressure applied, the scanner will detach easily.
      댓글 쓰기
    7. Scanner Head Replacement: 7 단계, 이미지 1개 중 1개
      • Gently grasp and unplug the two white ribbon cables from the printer body.
      • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
      댓글 쓰기
    8. Scanner Head Replacement: 8 단계, 이미지 1개 중 1개
      • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
      • Be sure to grasp the white connector and not to pull on the wires themselves.
      댓글 쓰기
    9. Scanner Head Replacement, Detaching the Scanner Tray: 9 단계, 이미지 1개 중 1개
      • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
      댓글 쓰기
    1. Scanner Head Replacement, Detaching the Scanner Head: 10 단계, 이미지 2개 중 1개 Scanner Head Replacement, Detaching the Scanner Head: 10 단계, 이미지 2개 중 2개
      • Detach the white ribbon wire from the scanner head by pulling gently at the connection.
      댓글 쓰기
    2. Scanner Head Replacement, Removing the Scanner Head: 11 단계, 이미지 2개 중 1개 Scanner Head Replacement, Removing the Scanner Head: 11 단계, 이미지 2개 중 2개
      • Lift the gray drive belt from the black tab to disconnect the drive belt from the scanner head.
      • Remove the scanner head from the scanner by gently rotating and then lifting.
      댓글 쓰기
    3. Scanner Head Replacement, Adding New Scanner Head: 12 단계, 이미지 2개 중 1개 Scanner Head Replacement, Adding New Scanner Head: 12 단계, 이미지 2개 중 2개
      • Place the new scanner head in the scanner tray by fastening the drive belt into the black tab.
      • Make sure the tab on the outer portion of the gray drive belt is fastened.
      • Once the drive belt is secured, rotate the scanner head back into position.
      • Re-attach the white ribbon wire to the connection from Step 10.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Mackenzie Billings
회원 가입일: 04/05/11
577 평판
안내서 2개를 작성함
Cal Poly, Team 12-31, Maness Spring 2011 Cal Poly, Team 12-31, Maness Spring 2011 회원
CPSU-MANESS-S11S12G31
5 회원들
안내서 63개를 작성함
2가이드 댓글
Ok, but where do I purchase a new scanner head???
Nichelle King - 답글 공유
the step between 9 and 10 doesn't seem to make sense. it never established that the scanner head is broken...I couldn't identify where step 10 scanner head came up ...no where did it show the scanner between step 1 and step 9...Please offer an explanation...
by step 9 the scanner package had already removed...i m afraid I wont here from ifixit because the printer is about 20 years old.
winston ho - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 48
전체 시간: 12,693
