주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Schwinn Tourist Inner Tube Replacement
필요한 것
    1. Schwinn Tourist Inner Tube Replacement, Front Inner Tube: 1 단계, 이미지 1개 중 1개
      • Flip the bicycle upside down.
      • By flipping the bicycle upside down it will offer additional support by being able to stand up by itself.
      댓글 쓰기
    2. Schwinn Tourist Inner Tube Replacement, Loosen The Brakes: 2 단계, 이미지 1개 중 1개
      • Apply pressure to both sides of the brake arm with one hand and lift the metal brake cable from the brake caliper.
      • By releasing the brake cable from the brake caliper, it will loosen the brake pads by the tire.
      댓글 쓰기
    3. Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: 3 단계, 이미지 2개 중 1개 Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: 3 단계, 이미지 2개 중 2개
      • Push the quick release lever outwards towards your body.
      • While holding the other end of the quick release lever, rotate the lever counter-clockwise until it is loose.
      댓글 쓰기
    4. Schwinn Tourist Inner Tube Replacement, Remove Tire: 4 단계, 이미지 1개 중 1개
      • Lift the tire to remove it from the bicycle.
      댓글 쓰기
    5. Schwinn Tourist Inner Tube Replacement, Inserting The Tire Lever: 5 단계, 이미지 1개 중 1개
      • Insert the flat end of the tire lever between the inside wall of the tire and the outside of the rim.
      • Attach the other end of the tire lever to the nearest spoke on the rim.
      댓글 쓰기
    6. Schwinn Tourist Inner Tube Replacement, Insering Second Tire Lever: 6 단계, 이미지 1개 중 1개
      • Insert a second tire lever next to the first lever to create leverage for releasing the tire from the rim.
      댓글 쓰기
    7. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: 7 단계, 이미지 1개 중 1개
      • Leave the first lever in place. Slide the second lever against the outside edge of the rim until one side of the tire is off of the rim.
      댓글 쓰기
    8. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: 8 단계, 이미지 1개 중 1개
      • Reattach the the first lever to the other side of the tire and repeat steps 4-7 to remove tire completely from rim.
      댓글 쓰기
    9. Schwinn Tourist Inner Tube Replacement, Remove the Valve Stem: 9 단계, 이미지 1개 중 1개
      • Push the valve stem upwards through the hole in the rim.
      댓글 쓰기
    10. Schwinn Tourist Inner Tube Replacement, Finished: 10 단계, 이미지 1개 중 1개
      • Once valve stem is pushed, pull the inner tube until it is completely removed from the rim.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Quandre Mebane
회원 가입일: 10/07/14
149 평판
안내서 1개를 작성함
USF Tampa, Team 1-22, Donnelly Fall 2014 USF Tampa, Team 1-22, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G22
1 회원
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 35
전체 시간: 5,618
