주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Seagate Backup Plus Hub Disassembly
필요한 것
    1. Seagate Backup Plus Hub Disassembly, Needed a Hard Drive: 1 단계, 이미지 2개 중 1개 Seagate Backup Plus Hub Disassembly, Needed a Hard Drive: 1 단계, 이미지 2개 중 2개
      • I needed a hard drive and there are no cheap computer stores in the area, so I bought a Seagate Backup Plus Hub at Costco to remove the drive.
      • You can see where I broke the case trying to remove it.
      댓글 쓰기
    2. Seagate Backup Plus Hub Disassembly, Plastic Case Parts: 2 단계, 이미지 3개 중 1개 Seagate Backup Plus Hub Disassembly, Plastic Case Parts: 2 단계, 이미지 3개 중 2개 Seagate Backup Plus Hub Disassembly, Plastic Case Parts: 2 단계, 이미지 3개 중 3개
      • The plastic case is composed of three parts held together with clips.
      • You are supposed to take off the flat top first, and then the sides.
      • Unfortunately, I didn't know what it looked like inside, and I still don't know how to open the clips without breaking them.
      댓글 쓰기
    3. Seagate Backup Plus Hub Disassembly, Case Details: 3 단계, 이미지 3개 중 1개 Seagate Backup Plus Hub Disassembly, Case Details: 3 단계, 이미지 3개 중 2개 Seagate Backup Plus Hub Disassembly, Case Details: 3 단계, 이미지 3개 중 3개
      • Here are some close-ups. Yous can see where I broke most of the plastic clips.
      댓글 쓰기
    4. Seagate Backup Plus Hub Disassembly, Drive Details: 4 단계, 이미지 2개 중 1개 Seagate Backup Plus Hub Disassembly, Drive Details: 4 단계, 이미지 2개 중 2개
      • Hard drive is a Seagate ST5000DM000-1FK178
      • The drive is optimized for storage so it is LARGE and SLOW.
      • Some people are removing it from an enclosure and selling on Ebay or Amazon. You get a big drive, but not a very good one.
      • I'm going to have to buy another drive.
      댓글 쓰기
결론
I couldn't put it back together again. And this turned out to be a BAD IDEA since the drive is very SLOW.
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alan Nishioka
회원 가입일: 07/17/11
3,655 평판
안내서 8개를 작성함
13가이드 댓글
I just wanted to add to this guide. I tried to disassemble it as well. I started by removing the top. As you described I could not find a way to remove the plastic top without damaging the plastic clips. Once the top was removed I was able to remove all the internal components without any issues. To remove the hard drive I unclipped all the plastic clips on the inside of the frame, lifted up the frame and slid the hard drive out of the back of the case.
I have the 8TB version. It uses a Seagate Archive HDD based on SMR technology. It is not fast but good for inexpensive mass storage.
Joel Oscarsson - 답글 공유
By removing the plastic clips, the casing can easily hold itself together, when only removing the top and wile NOT damaging the HDD frame.
By removing the top i only made some small cosmetic damage at the buttom of the HDD frame and the plastic top as the only damge to the case. (And the of course the plastic clips)
I could not se any way to NOT damage the plastic clips.
Mikki Sørensen - 답글 공유
Part 1
Use a very small blade screwdriver to get into the gap between rear panel and the large cover that goes round the front and surrounds the 2 usb externals.
Starting at one edge force the tip of the screwdriver in and twist till you get a little gap, then unsert a larger screwdriver blade and twist till the clip pops off.
Move little screww driver to the other side of the bigger one and then move the larger screw driver pass the little one and twist etc
When you get past half way use two more screwdrivers to do the same around the corner where you started. Once you pop a clip around the corner leave the larger screwdriver in the gap and return to the end piece. (Doing the corner now helps stop the end clips slipping back into place.
Continue the end and then do two clips around the corner, then return to the other side and do two clips, then back to the other side and do two clips.
From here you should be able to do the rest with your hands by tilting the cover up.
drdoug_au - 답글 공유
Part 2
Once the cover is off the drive and electronics just slips out by turning the case open side down, four screws behind the rubber vibration washers and you can unplug it.
Reassembly must be done exactly in reverse from a tilted position at the2 x usb plugs end. You will damage some clips, but I got mine back together ok.
drdoug_au - 답글 공유
My interest was simply getting the drive out so I could use it connected as a native SATA drive. Expect to wreck the case if this is your goal. As proposed above, remove the flat size. Metal prying tools in my iFixit kit were better for this, the overall strength of this assemble case bested the plastic “pry” tools. Once I had the assembly open, the back (power) end of the system went next; average sized pliers cracked the back and I could pry it and one side away. Eventually you will have a metal chassis in hand. remove the four side screws, and the drive pops off the power/data ports quite easily. If you want to preserve the case disassembly is NOT advised. It appears it was made to snap together and break upon disassembly. Total “destructive” disassembly took about 20 minutes.
Doug Austin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 25
지난 30일: 174
전체 시간: 48,124
