주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sega Dreamcast Controller Port Replacement
필요한 것
  1. Sega Dreamcast Controller Port Replacement, Expansion Bay: 1 단계, 이미지 2개 중 1개 Sega Dreamcast Controller Port Replacement, Expansion Bay: 1 단계, 이미지 2개 중 2개
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
    댓글 쓰기
  2. Sega Dreamcast Controller Port Replacement: 2 단계, 이미지 3개 중 1개 Sega Dreamcast Controller Port Replacement: 2 단계, 이미지 3개 중 2개 Sega Dreamcast Controller Port Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
    댓글 쓰기
  3. Sega Dreamcast Controller Port Replacement, Top Cover: 3 단계, 이미지 1개 중 1개
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
    댓글 쓰기
  4. Sega Dreamcast Controller Port Replacement: 4 단계, 이미지 1개 중 1개
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
    댓글 쓰기
  5. Sega Dreamcast Controller Port Replacement, Controller Port: 5 단계, 이미지 2개 중 1개 Sega Dreamcast Controller Port Replacement, Controller Port: 5 단계, 이미지 2개 중 2개
    • Be gentle with the white controller cable as it can be a bit fragile.
    • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
    댓글 쓰기
  6. Sega Dreamcast Controller Port Replacement: 6 단계, 이미지 2개 중 1개 Sega Dreamcast Controller Port Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the four 14mm Philips #02 screws located on the controller board.
    댓글 쓰기
  7. Sega Dreamcast Controller Port Replacement: 7 단계, 이미지 2개 중 1개 Sega Dreamcast Controller Port Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the white fan header from the controller port.
    댓글 쓰기
  8. Sega Dreamcast Controller Port Replacement: 8 단계, 이미지 2개 중 1개 Sega Dreamcast Controller Port Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the controller board by lifting it up from the controller port.
    댓글 쓰기
  9. Sega Dreamcast Controller Port Replacement, Controller Port: 9 단계, 이미지 1개 중 1개
    • Flip the controller board on its underside so that the solder joints are exposed.
    댓글 쓰기
  10. Sega Dreamcast Controller Port Replacement: 10 단계, 이미지 2개 중 1개 Sega Dreamcast Controller Port Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the F1 fuse by using the soldering iron and desoldering wick.
    • The F1 fuse is clearly indicated on the topside of the controller board.
    • If the F1 through-hole of the circuit board is not visible, you may clean the it by removing the excess solder by using the soldering iron and desoldering wick.
    댓글 쓰기
  11. Sega Dreamcast Controller Port Replacement: 11 단계, 이미지 2개 중 1개 Sega Dreamcast Controller Port Replacement: 11 단계, 이미지 2개 중 2개
    • If you are not using a fuse resistor, skip this step. Otherwise, continue.
    • Insert and solder the new fuse resistor to F1 socket.
    • The fuse resistor should sit on the topside of the board and the leads should be exposed on the underside. Orientation of the fuse resistor does not matter
    • The 10M 1/2 watt resistor in the picture is used to depict what a fuse resistor might look like.
    댓글 쓰기
  12. Sega Dreamcast Controller Port Replacement: 12 단계, 이미지 2개 중 1개 Sega Dreamcast Controller Port Replacement: 12 단계, 이미지 2개 중 2개
    • If you have already used a fuse resistor to complete the previous step, you may omit this step.
    • Insert and solder the parallel 10 ohm 1/4 watt resistors to the F1 socket.
    • The resistors should be laid out on the top side of the circuit board and the leads should poke out from the underside. The orientation of the resistor does not matter.
    • The 1/4 watt resistors shown in the picture are used to depict what parallel resistors should look like.
    댓글 쓰기
  13. Sega Dreamcast Controller Port Replacement: 13 단계, 이미지 1개 중 1개
    • Verify that the resistor(s) leads do not touch other components on the topside of the circuit board. Otherwise, a short circuit may occur when you power on the system.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Darren Chan
회원 가입일: 10/28/09
5,388 평판
안내서 2개를 작성함
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 29개를 작성함
6가이드 댓글
Hello, Darren. I am having the utmost difficulty doing this with two 1/4 watt resistors, as you have demonstrated. I have three dreamcast systems, I would like to repair (all with a bad controller port.) What would be the chance that I could send you the ports, packs of resistors and and solder and pay you to do this to all of them?
djresree - 답글 공유
I would even be willing to give you two of them! I just want one working system!
djresree - 답글 공유
I can help with this, email me at yahoo address
rhedayi - 답글 공유
bonjour Darren. Ma question est surement bête mais est- ce que cette manipulation est nécessaire quand seul le premier port de la Dreamcast ne fonctionne pas ??
etra782a - 답글 공유
I need this board, were do I find one?
Andrew Trumbo - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 33
지난 30일: 175
전체 시간: 41,004
