주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sega Genesis Flashback Controller Batteries Replacement
필요한 것
  1. Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: 1 단계, 이미지 2개 중 1개 Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: 1 단계, 이미지 2개 중 2개
    • Using a Phillips #000 screwdriver, unscrew the single screw located on the battery cover. Remove the battery cover and set it aside.
    • The screw does not detach from the battery cover, so do not attempt to separate them.
    댓글 쓰기
  2. Sega Genesis Flashback Controller Batteries Replacement: 2 단계, 이미지 2개 중 1개 Sega Genesis Flashback Controller Batteries Replacement: 2 단계, 이미지 2개 중 2개
    • If batteries are in the battery slots and need to be replaced, then remove the old batteries by pressing them in and compressing the spring until there is enough space to take them out.
    • Insert two fresh batteries into each one of the slots by pushing the indicated negative end of the battery against the spring.
    • All AAA batteries have “+” and “-” symbols on each end of the batteries to denote the positive and negative ends.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Omar Shorab
회원 가입일: 04/23/18
261 평판
안내서 2개를 작성함
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 회원
CPSU-MANESS-S18S24G12
4 회원들
안내서 10개를 작성함
1가이드 댓글
any idea where i can find a schematic for the contoller board. I just bought one of these second hand and the wireless controller won’t connect to the system. I took it apart and it’s missing a small resistor.
Scott Phaneuf - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 55
전체 시간: 3,316
