주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sennheiser RS120 Battery Replacement
필요한 것
    1. Sennheiser RS120 Battery Replacement, Ear Pad: 1 단계, 이미지 3개 중 1개 Sennheiser RS120 Battery Replacement, Ear Pad: 1 단계, 이미지 3개 중 2개 Sennheiser RS120 Battery Replacement, Ear Pad: 1 단계, 이미지 3개 중 3개
      • Grip the ear pad with one hand and steady the headset on the other.
      • Twist the ear pad counterclockwise, then lift the ear pad off after about an eighth of an inch of the turn.
      • Replace the old ear pad with a new ear pad.
      댓글 쓰기
    1. Sennheiser RS120 Battery Replacement, Battery: 2 단계, 이미지 2개 중 1개 Sennheiser RS120 Battery Replacement, Battery: 2 단계, 이미지 2개 중 2개
      • Twist the left ear pad counterclockwise to reveal the battery compartment within the headphone.
      • To remove batteries, push inward and lift up.
      • The battery should be able to pop out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Gayle Dunham
회원 가입일: 03/03/10
393 평판
안내서 1개를 작성함
8가이드 댓글
Thanks for the information - this made changing the batteries a snap.
Jim K - 답글 공유
Extremely helpful. Thank you!
-Randy N
Randy - 답글 공유
I own three sets and one quit working. As it turns out that the rechargeable batteries in that one set need replacing.
Until I purchase some rechargeable batteries, I am using standard AAA batteries and just have to remember NOT to put the headset back on the cradle.
Thanks for the info on how to access the batteries !
mcgilljp - 답글 공유
Thanks! You solved my mystery.
Marilyn Carini - 답글 공유
Good information, I wouldn’t have had a clue without it. Many thanks
Geoff Smith - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 112
전체 시간: 48,933
