주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Seville Classics MSC10166 Disassembly
필요한 것
    1. Seville Classics MSC10166 Disassembly, PCB (Printed Circuit Board): 1 단계, 이미지 1개 중 1개
      • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
      댓글 쓰기
    2. Seville Classics MSC10166 Disassembly: 2 단계, 이미지 1개 중 1개
      • Pull the front and back cover apart.
      • Be careful not to pull the front cover off completely. It holds the wires.
      댓글 쓰기
    3. Seville Classics MSC10166 Disassembly: 3 단계, 이미지 1개 중 1개
      • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
      • Shock warning: Make sure the fan is unplugged before removing the circuit board.
      댓글 쓰기
    4. Seville Classics MSC10166 Disassembly: 4 단계, 이미지 1개 중 1개
      • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
      댓글 쓰기
    5. Seville Classics MSC10166 Disassembly: 5 단계, 이미지 2개 중 1개 Seville Classics MSC10166 Disassembly: 5 단계, 이미지 2개 중 2개
      • Remove the screws from the four corners of the circuit board.
      • Remove the circuit board from the top cover.
      • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
      댓글 쓰기
    1. Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: 6 단계, 이미지 2개 중 1개 Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: 6 단계, 이미지 2개 중 2개
      • In order to remove the fan blade, use pliers to remove the holding nut.
      • After the holding nut is loose, use the pliers to pull up to remove the nut.
      댓글 쓰기
    2. Seville Classics MSC10166 Disassembly: 7 단계, 이미지 1개 중 1개
      • Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
      • Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
      댓글 쓰기
    3. Seville Classics MSC10166 Disassembly: 8 단계, 이미지 2개 중 1개 Seville Classics MSC10166 Disassembly: 8 단계, 이미지 2개 중 2개
      • Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
      • Remove screws by pulling them away from the base.
      • The transformer should be free after this step.
      댓글 쓰기
    1. Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: 9 단계, 이미지 2개 중 1개 Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: 9 단계, 이미지 2개 중 2개
      • Clean the track, removing any obstructions.
      • Lubricate the track with grease.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Queena Phung
회원 가입일: 09/26/12
114 평판
안내서 3개를 작성함
Cal Poly, Team 15-46, Forte Fall 2012 Cal Poly, Team 15-46, Forte Fall 2012 회원
CPSU-FORTE-F12S15G46
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 142
전체 시간: 12,762
