소개
This guide for the Shark AI Ultra AV2511AE will show the steps needed to successfully replace the vacuum battery. This is necessary when your vacuum will not power on or the vacuum's battery depletes quickly. Ensure that your device is turned off before disassembly because there will be a wire disconnection. Take proper precaution when removing the battery as it may be swollen.
필요한 것
Orient the device upside-down
Remove two 15 mm screws using a Phillips #1 screwdriver.
Remove the battery cover.
거의 끝나갑니다!
결론
