주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shark ION Robot R75 Side Sensor Replacement
필요한 것
    1. Shark ION Robot R75 Side Sensor Replacement, Battery: 1 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement, Battery: 1 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Make sure the robot is shut off by pressing the power button on top.
      • Flip the R75 over so that the underside is facing up.
      • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
      • Remove the battery cover.
      댓글 쓰기
    2. Shark ION Robot R75 Side Sensor Replacement: 2 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 2 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement: 2 단계, 이미지 3개 중 3개
      • Be careful when removing the battery, as it will still be connected to a wire.
      • Slowly pull the white tabs outward to remove the battery.
      댓글 쓰기
    3. Shark ION Robot R75 Side Sensor Replacement: 3 단계, 이미지 2개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Be careful when removing the connector, as the part can break if too much force is used.
      • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
      • Remove the battery from the device.
      댓글 쓰기
    1. Shark ION Robot R75 Side Sensor Replacement, Main Brush: 4 단계, 이미지 1개 중 1개
      • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
      댓글 쓰기
    2. Shark ION Robot R75 Side Sensor Replacement: 5 단계, 이미지 1개 중 1개
      • Pull the main brush slightly to the right to remove it from the compartment.
      댓글 쓰기
    3. Shark ION Robot R75 Side Sensor Replacement: 6 단계, 이미지 2개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the rubber end cap indicated by the red circle.
      • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
      • Inspect this component at least every six months. This time may be less if you have animals.
      댓글 쓰기
    1. Shark ION Robot R75 Side Sensor Replacement, Side Brush: 7 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement, Side Brush: 7 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement, Side Brush: 7 단계, 이미지 3개 중 3개
      • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
      • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
      댓글 쓰기
    1. Shark ION Robot R75 Side Sensor Replacement, Drive Wheel Assembly: 8 단계, 이미지 1개 중 1개
      • Flip the R75 to its underside.
      • Make sure the R75 is shut off.
      • For extra security, disconnect the battery by following the prerequisite guide.
      댓글 쓰기
    2. Shark ION Robot R75 Side Sensor Replacement: 9 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 9 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement: 9 단계, 이미지 3개 중 3개
      • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
      • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
      • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
      댓글 쓰기
    3. Shark ION Robot R75 Side Sensor Replacement: 10 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 10 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement: 10 단계, 이미지 3개 중 3개
      • Flip the wheel assembly over and disconnect the cable connector on its underside.
      • Remove the drive wheel assembly.
      • Repeat this process for the other side if necessary.
      댓글 쓰기
    1. Shark ION Robot R75 Side Sensor Replacement, Shark ION Robot R75 Caster Wheel: 11 단계, 이미지 1개 중 1개
      • Orient the device with the bottom facing up.
      댓글 쓰기
    2. Shark ION Robot R75 Side Sensor Replacement: 12 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 12 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement: 12 단계, 이미지 3개 중 3개
      • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
      • Remove the wheel.
      댓글 쓰기
    3. Shark ION Robot R75 Side Sensor Replacement: 13 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 13 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement: 13 단계, 이미지 3개 중 3개
      • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
      • Pull the caster assembly up from its slot in the device.
      댓글 쓰기
    1. Shark ION Robot R75 Side Sensor Replacement, Top Cover: 14 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement, Top Cover: 14 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement, Top Cover: 14 단계, 이미지 3개 중 3개
      • Push down on the black tab and remove the dust bin
      댓글 쓰기
    2. Shark ION Robot R75 Side Sensor Replacement: 15 단계, 이미지 2개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 15 단계, 이미지 2개 중 2개
      • Using a Torx TR15 screwdriver, remove the five screws from the bottom cover.
      댓글 쓰기
    3. Shark ION Robot R75 Side Sensor Replacement: 16 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 16 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement: 16 단계, 이미지 3개 중 3개
      • Make sure the robot is facing rearward
      • Using a Torx TR15 screwdriver, remove the five screws along the front edge of the device.
      • Pull the bottom part of the bump guard away from the body of the device.
      댓글 쓰기
    4. Shark ION Robot R75 Side Sensor Replacement: 17 단계, 이미지 3개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 17 단계, 이미지 3개 중 2개 Shark ION Robot R75 Side Sensor Replacement: 17 단계, 이미지 3개 중 3개
      • Lift the top cover up from the rear of the robot to separate the top cover from the rest of the robot.
      • Be careful when separating the top from the rest of the robot, as the plastic clips can break if excessive force is applied.
      • From here, easy access to all sensors, the main brush motor, and the fan are all granted.
      댓글 쓰기
    1. Shark ION Robot R75 Side Sensor Replacement, Side Sensor: 18 단계, 이미지 2개 중 1개 Shark ION Robot R75 Side Sensor Replacement, Side Sensor: 18 단계, 이미지 2개 중 2개
      • Using a Phillips #00 screwdriver, remove the screw holding down the diagonally vented side cover.
      • Slide the sensor out from the base of the robot
      댓글 쓰기
    2. Shark ION Robot R75 Side Sensor Replacement: 19 단계, 이미지 2개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 19 단계, 이미지 2개 중 2개
      • Lift up the diagonally vented cover on the side of the robot containing the side sensor.
      댓글 쓰기
    3. Shark ION Robot R75 Side Sensor Replacement: 20 단계, 이미지 2개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 20 단계, 이미지 2개 중 2개
      • Disconnect the white connector from the sensor.
      댓글 쓰기
    4. Shark ION Robot R75 Side Sensor Replacement: 21 단계, 이미지 2개 중 1개 Shark ION Robot R75 Side Sensor Replacement: 21 단계, 이미지 2개 중 2개
      • Using a Phillips #00 screwdriver, remove the screw on the sensor.
      • Remove the sensor from its mount.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Lowy
회원 가입일: 01/25/20
599 평판
안내서 4개를 작성함
1가이드 댓글
Curious if anyone ever saw the WiFi die in these? I cannot get the shark WiFi to show so I can add it to the network. I press both the bottoms and the icon flashes but shark WiFi never shows so the app can continue.
Shawn Winters - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 44
전체 시간: 20,087
