주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shark Navigator Lightweight Upright Motor Replacement
필요한 것
    1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: 1 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motor Replacement, Head Shell: 1 단계, 이미지 2개 중 2개
      • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
      댓글 쓰기
    2. Shark Navigator Lightweight Upright Motor Replacement: 2 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motor Replacement: 2 단계, 이미지 2개 중 2개
      • Lay the vacuum on its side.
      • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
      댓글 쓰기
    3. Shark Navigator Lightweight Upright Motor Replacement: 3 단계, 이미지 1개 중 1개
      • Flip over the vacuum head so the brush head is facing up.
      댓글 쓰기
    4. Shark Navigator Lightweight Upright Motor Replacement: 4 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Motor Replacement: 4 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Motor Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
      • Repeat this for the other wheel.
      댓글 쓰기
    5. Shark Navigator Lightweight Upright Motor Replacement: 5 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motor Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the two 18mm screws with a JIS 1 screwdriver.
      댓글 쓰기
    6. Shark Navigator Lightweight Upright Motor Replacement: 6 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motor Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
      댓글 쓰기
    7. Shark Navigator Lightweight Upright Motor Replacement: 7 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motor Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
      댓글 쓰기
    8. Shark Navigator Lightweight Upright Motor Replacement: 8 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Motor Replacement: 8 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Motor Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
      • Prying in multiple locations may be necessary to create separation.
      댓글 쓰기
    1. Shark Navigator Lightweight Upright Motor Replacement, Motor: 9 단계, 이미지 1개 중 1개
      • Locate the motor on the top right corner of the vacuum head shell.
      댓글 쓰기
    2. Shark Navigator Lightweight Upright Motor Replacement: 10 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Motor Replacement: 10 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Motor Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the belt from the motor gear by sliding the belt to the right.
      댓글 쓰기
    3. Shark Navigator Lightweight Upright Motor Replacement: 11 단계, 이미지 3개 중 1개 Shark Navigator Lightweight Upright Motor Replacement: 11 단계, 이미지 3개 중 2개 Shark Navigator Lightweight Upright Motor Replacement: 11 단계, 이미지 3개 중 3개
      • Remove the white metal wire connector from the motor.
      • The white cable is positive.
      댓글 쓰기
    4. Shark Navigator Lightweight Upright Motor Replacement: 12 단계, 이미지 2개 중 1개 Shark Navigator Lightweight Upright Motor Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the black metal wire connector from the motor.
      • The black cable is negative.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Suzie
회원 가입일: 10/02/17
545 평판
안내서 4개를 작성함
Cal Poly, Team S4-G6, Livingston Fall 2017 Cal Poly, Team S4-G6, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G6
3 회원들
안내서 30개를 작성함
2가이드 댓글
Where does one buy the replacement motor?
Michael De La Rosa - 답글 공유
Where can I get spares??
ck
Clive Kingscote - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 47
전체 시간: 10,589
