주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shark Rocket HV301 Hose Replacement
필요한 것
    1. Shark Rocket HV301 Hose Replacement, Hose: 1 단계, 이미지 3개 중 1개 Shark Rocket HV301 Hose Replacement, Hose: 1 단계, 이미지 3개 중 2개 Shark Rocket HV301 Hose Replacement, Hose: 1 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      T4 Torx Screwdriver
      $5.49
      • Place the base of the vacuum face down so the roller brush is facing you.
      • Locate the five screws and remove the screws using a Phillips #1 screwdriver. On some models, the screws may be Torx T4 instead of Phillips.
      • On some models, you may need to remove the two screws next to the big wheels, under the top two circled screws in the picture, with a Torx T3 screwdriver.
      • You may want to disconnect the base from the stick of the vacuum to make it easier to move around.
      댓글 쓰기
    2. Shark Rocket HV301 Hose Replacement: 2 단계, 이미지 2개 중 1개 Shark Rocket HV301 Hose Replacement: 2 단계, 이미지 2개 중 2개
      • Locate and remove the two small wheels below the roller brush by prying with a plastic prying tool.
      • This may require some force.
      댓글 쓰기
    3. Shark Rocket HV301 Hose Replacement: 3 단계, 이미지 3개 중 1개 Shark Rocket HV301 Hose Replacement: 3 단계, 이미지 3개 중 2개 Shark Rocket HV301 Hose Replacement: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      T4 Torx Screwdriver
      $5.49
      • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
      • Pull up on the plate covering the roller brush and remove it.
      • On some models, you may need to remove 3 additional screws under the roller brush cover with a Torx T4 screwdriver. (Not pictured.)
      댓글 쓰기
    4. Shark Rocket HV301 Hose Replacement: 4 단계, 이미지 3개 중 1개 Shark Rocket HV301 Hose Replacement: 4 단계, 이미지 3개 중 2개 Shark Rocket HV301 Hose Replacement: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      iFixit Opening Picks (Set of 6)
      $4.95
      • Turn the vacuum over so the roller brush is on the ground.
      • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
      • It may help to slip opening picks in the edge between the gray cover and the orange and clear base sections.
      댓글 쓰기
    5. Shark Rocket HV301 Hose Replacement: 5 단계, 이미지 3개 중 1개 Shark Rocket HV301 Hose Replacement: 5 단계, 이미지 3개 중 2개 Shark Rocket HV301 Hose Replacement: 5 단계, 이미지 3개 중 3개
      • Gently pinch head of cable and pull upwards until upper casing disconnects from vacuum and proceed with removing upper casing.
      • Return the vacuum to its original position with the roller brush facing you.
      • Locate the screw to the right of the vacuum hose, close to the right wheel, and remove the screw with a Phillips #2 screwdriver.
      • Note: some models may not include this screw.
      댓글 쓰기
    6. Shark Rocket HV301 Hose Replacement: 6 단계, 이미지 3개 중 1개 Shark Rocket HV301 Hose Replacement: 6 단계, 이미지 3개 중 2개 Shark Rocket HV301 Hose Replacement: 6 단계, 이미지 3개 중 3개
      • Pull on the dark gray end of the hose that attaches to the roller brush chamber to remove the hose from the base.
      • Unscrew the hose from the dark gray end by twisting it clockwise.
      • Unscrew the hose out of the chamber that attaches the stick to the base by twisting it clockwise. The hose is glued into the chamber, so this may require some force.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 35명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Shelby Baccala
회원 가입일: 10/06/16
847 평판
안내서 1개를 작성함
Cal Poly, Team 10-5, Livingston Fall 2016 Cal Poly, Team 10-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G5
4 회원들
안내서 20개를 작성함
62가이드 댓글
Great instructions, now where do I get the replacement hose. I can't seem to find one anywhere, please tell be where to look
Kay Fisher - 답글 공유
Rob the hose from the hard floor attachment, you probably do not use it as at low speed the brush head is awesome on hard floors.
Suzannne Scheans - 답글 공유
I found a hose that is a perfect fit. EVERBILT 6 ft Bilge and Pump Discharge Hose. 1-1/8 inch ID. Got it at Home Depot.
Nick Verciglio - 답글 공유
How did you get the hose from Home Depot to work? I’d like to try it, and I was hoping you would give some advice.
Joey Griffin - 답글 공유
Thank you so much for this recommendation! The Everbilt Bilge and Pump hose works perfectly!!! And now I have back up if I need to replace it again.
Thank you for the instructions as well Shelby! So much better than spending another $50 on a replacement head!
irishernie - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 43
지난 30일: 278
전체 시간: 94,367
