주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shark Rocket HV301 Rotary Belt Replacement
필요한 것
    1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: 1 단계, 이미지 3개 중 1개 Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: 1 단계, 이미지 3개 중 2개 Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: 1 단계, 이미지 3개 중 3개
      • Flip the vacuum so the bottom base is visible.
      • Gently pry the bottom two wheels off with a plastic opening tool.
      댓글 쓰기
    2. Shark Rocket HV301 Rotary Belt Replacement: 2 단계, 이미지 3개 중 1개 Shark Rocket HV301 Rotary Belt Replacement: 2 단계, 이미지 3개 중 2개 Shark Rocket HV301 Rotary Belt Replacement: 2 단계, 이미지 3개 중 3개
      • Remove five visible screws with a Phillips #2 screwdriver.
      • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
      댓글 쓰기
    3. Shark Rocket HV301 Rotary Belt Replacement: 3 단계, 이미지 3개 중 1개 Shark Rocket HV301 Rotary Belt Replacement: 3 단계, 이미지 3개 중 2개 Shark Rocket HV301 Rotary Belt Replacement: 3 단계, 이미지 3개 중 3개
      • Remove plate covering the roller brush.
      댓글 쓰기
    4. Shark Rocket HV301 Rotary Belt Replacement: 4 단계, 이미지 2개 중 1개 Shark Rocket HV301 Rotary Belt Replacement: 4 단계, 이미지 2개 중 2개
      • Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
      댓글 쓰기
    5. Shark Rocket HV301 Rotary Belt Replacement: 5 단계, 이미지 3개 중 1개 Shark Rocket HV301 Rotary Belt Replacement: 5 단계, 이미지 3개 중 2개 Shark Rocket HV301 Rotary Belt Replacement: 5 단계, 이미지 3개 중 3개
      • Turn the vacuum over so the rotary brush is on the ground.
      • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
      댓글 쓰기
    6. Shark Rocket HV301 Rotary Belt Replacement: 6 단계, 이미지 2개 중 1개 Shark Rocket HV301 Rotary Belt Replacement: 6 단계, 이미지 2개 중 2개
      • Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
      • Proceed with removing the upper casing.
      댓글 쓰기
    7. Shark Rocket HV301 Rotary Belt Replacement: 7 단계, 이미지 2개 중 1개 Shark Rocket HV301 Rotary Belt Replacement: 7 단계, 이미지 2개 중 2개
      • Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
      댓글 쓰기
    8. Shark Rocket HV301 Rotary Belt Replacement: 8 단계, 이미지 3개 중 1개 Shark Rocket HV301 Rotary Belt Replacement: 8 단계, 이미지 3개 중 2개 Shark Rocket HV301 Rotary Belt Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the rotary belt on right side of vacuum from the bearing.
      • Gently lift the casing to remove the belt and brush from the vacuum.
      댓글 쓰기
    9. Shark Rocket HV301 Rotary Belt Replacement: 9 단계, 이미지 3개 중 1개 Shark Rocket HV301 Rotary Belt Replacement: 9 단계, 이미지 3개 중 2개 Shark Rocket HV301 Rotary Belt Replacement: 9 단계, 이미지 3개 중 3개
      • Gently pry off the plastic casing on both sides of rotary brush.
      • Lift the clear plastic shell from the rotary brush.
      댓글 쓰기
    10. Shark Rocket HV301 Rotary Belt Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the rotary belt attached to the brush and replace it if needed.
      댓글 쓰기
    1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Belt: 11 단계, 이미지 1개 중 1개
      • Replace belt if torn or damaged.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Trey Nahhas
회원 가입일: 10/06/16
848 평판
안내서 1개를 작성함
Cal Poly, Team 10-5, Livingston Fall 2016 Cal Poly, Team 10-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G5
4 회원들
안내서 20개를 작성함
4가이드 댓글
Where can I find the rotary belt for the Shark Duo?
oneupchallenges - 답글 공유
I could not get it out without removing the brush roll motor. So I am putting it back together and I need to know if the motor has a top and bottom. What I mean is does it matter ? Thank you
Jennifer Dalton - 답글 공유
Thanks for the guide it came in super handy
SYSTEM 855 - 답글 공유
I just wish there were instructions on how to put the vacuum cleaner back together. I have memory issues and have a hard time going in reverse when I look at the dissembly process.
The Instructions were on the spot and even someone like me was able to disassemble the Shark Rocket.
Now to figure out how to reassemble it.
Thank you,
John
John Bartkowski - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 51
지난 30일: 194
전체 시간: 38,145
