주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shark Rocket Professional Hose Replacement
필요한 것
    1. Shark Rocket Professional Hose Replacement, Main Hose: 1 단계, 이미지 3개 중 1개 Shark Rocket Professional Hose Replacement, Main Hose: 1 단계, 이미지 3개 중 2개 Shark Rocket Professional Hose Replacement, Main Hose: 1 단계, 이미지 3개 중 3개
      • Look at the Shark Rocket Professional's Extension Rod.
      • Identify where the hose connects to the main body of the vacuum.
      • Press the tabs on the sides of the connector to remove the hose.
      • You can use a long, thin object to unclog the hose.
      • If this fixes your problem, then you are finished with this guide.
      댓글 쓰기
    2. Shark Rocket Professional Hose Replacement: 2 단계, 이미지 2개 중 1개 Shark Rocket Professional Hose Replacement: 2 단계, 이미지 2개 중 2개
      • Look at the vacuum handle and locate the orange button that says "Handle" with a picture of a lock.
      • Press the button and remove the handle.
      댓글 쓰기
    3. Shark Rocket Professional Hose Replacement: 3 단계, 이미지 2개 중 1개 Shark Rocket Professional Hose Replacement: 3 단계, 이미지 2개 중 2개
      • Look at the vacuum handle.
      • Using a T-15 screwdriver, remove the five 15mm screws in the handle by turning them counter-clockwise.
      댓글 쓰기
    4. Shark Rocket Professional Hose Replacement: 4 단계, 이미지 3개 중 1개 Shark Rocket Professional Hose Replacement: 4 단계, 이미지 3개 중 2개 Shark Rocket Professional Hose Replacement: 4 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to pry open the handle.
      • Don't worry if the handle sounds like it is going to break; it takes a lot of force to pull apart.
      • When popping open your handle, the small grey piece of plastic(pictured in the last frame) will fly out.
      댓글 쓰기
    5. Shark Rocket Professional Hose Replacement: 5 단계, 이미지 3개 중 1개 Shark Rocket Professional Hose Replacement: 5 단계, 이미지 3개 중 2개 Shark Rocket Professional Hose Replacement: 5 단계, 이미지 3개 중 3개
      • The orange plastic piece may have naturally fallen out at this point.
      • Look a your handle.
      • Using your hands, pull the tube from the nozzle of the handle.
      • The tube is soldered onto a wire connecting to the plastic orange piece inside the handle.
      • Cut this connection with wire clippers to remove and replace your tube.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brad Iglesia
회원 가입일: 01/24/18
316 평판
안내서 2개를 작성함
Cal Poly, Team S18-G6, Livingston Winter 2018 Cal Poly, Team S18-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G6
4 회원들
안내서 30개를 작성함
4가이드 댓글
How about an expla8nation about how t9 actually do the lower the hose inside the brush head
Jonathan Hill - 답글 공유
How do you replace the hose in the beater head
daveve2 - 답글 공유
Thank you for this, this guide helped a ton.
Bradlee Johnson - 답글 공유
How long does it take to answer acquestion?
daveve2 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 61
전체 시간: 6,977
