주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shark Rocket Professional Secondary Filters Replacement
    1. Shark Rocket Professional Secondary Filters Replacement, Dust Cup: 1 단계, 이미지 2개 중 1개 Shark Rocket Professional Secondary Filters Replacement, Dust Cup: 1 단계, 이미지 2개 중 2개
      • First, locate the button that says "Dust Cup". It is right next to the power button at the base of the handle.
      • Press the button down completely; you should feel a click.
      댓글 쓰기
    2. Shark Rocket Professional Secondary Filters Replacement: 2 단계, 이미지 1개 중 1개
      • Grab the handle of the dust cup, then pull up and away from the vacuum.
      • You must press the button and pull the dust cap simultaneously at first to release the latch.
      댓글 쓰기
    1. Shark Rocket Professional Secondary Filters Replacement, Secondary Filters: 3 단계, 이미지 3개 중 1개 Shark Rocket Professional Secondary Filters Replacement, Secondary Filters: 3 단계, 이미지 3개 중 2개 Shark Rocket Professional Secondary Filters Replacement, Secondary Filters: 3 단계, 이미지 3개 중 3개
      • As you look beneath the base of the dust cup, you will see a white foam filter. Remove this filter with your fingers.
      댓글 쓰기
    2. Shark Rocket Professional Secondary Filters Replacement: 4 단계, 이미지 1개 중 1개
      • Removing the first filter will reveal a second, thicker foam filter. Remove this as well.
      • Shark recommends that you rinse and air dry these filters monthly.
      • Remember to replace the filters in the correct order.
      댓글 쓰기
    3. Shark Rocket Professional Secondary Filters Replacement: 5 단계, 이미지 1개 중 1개
      • A dust filter is located within the dust cup. To access it, open the dust cup by pressing the orange tab on the front and pulling up on the handle.
      댓글 쓰기
    4. Shark Rocket Professional Secondary Filters Replacement: 6 단계, 이미지 1개 중 1개
      • Find the cylindrical screen in the center of the dust cap, grab the top, and pull it straight out.
      • If this filter is dirty, shake it or rinse it off to clean it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Theo Watkins
회원 가입일: 01/23/18
356 평판
안내서 2개를 작성함
Cal Poly, Team S18-G6, Livingston Winter 2018 Cal Poly, Team S18-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G6
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 38
전체 시간: 6,863
