주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sharper Image iPulse SI325 Light Intensity Dial Replacement
필요한 것
    1. Sharper Image iPulse SI325 Light Intensity Dial Replacement, Outer Case: 1 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 Light Intensity Dial Replacement, Outer Case: 1 단계, 이미지 2개 중 2개
      • Gently position the device so that the buttons and speakers lie face down.
      • Unplug the power cord from the "DC Input."
      댓글 쓰기
    2. Sharper Image iPulse SI325 Light Intensity Dial Replacement: 2 단계, 이미지 3개 중 1개 Sharper Image iPulse SI325 Light Intensity Dial Replacement: 2 단계, 이미지 3개 중 2개 Sharper Image iPulse SI325 Light Intensity Dial Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
      • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
      • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
      • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
      • A small gap will open as the two tabs are released.
      • Do not pull the two halves apart yet. They are held together by the speaker wire.
      댓글 쓰기
    3. Sharper Image iPulse SI325 Light Intensity Dial Replacement: 3 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 Light Intensity Dial Replacement: 3 단계, 이미지 2개 중 2개
      • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
      • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
      • Lay the device down, so that all the internal components are facing upwards.
      댓글 쓰기
    1. Sharper Image iPulse SI325 Light Intensity Dial Replacement, Light Intensity Dial: 4 단계, 이미지 1개 중 1개
      • Turn the device over so that the internals are facing down.
      • Remove the three 7mm Phillips #1 screws connecting the Zipconnect unit.
      댓글 쓰기
    2. Sharper Image iPulse SI325 Light Intensity Dial Replacement: 5 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 Light Intensity Dial Replacement: 5 단계, 이미지 2개 중 2개
      • Turn the device over again so you are looking at the internals.
      • The Zipconnect unit will lift out but will still be attached by a wire connected to the motherboard.
      • Remove the six 7mm Phillips #1 screws attatching the Zipconnect unit to the motherboard wire and set the unit out of the way.
      댓글 쓰기
    3. Sharper Image iPulse SI325 Light Intensity Dial Replacement: 6 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 Light Intensity Dial Replacement: 6 단계, 이미지 2개 중 2개
      • Next, disconnect the speaker wire from the motherboard by firmly griping the wires as close to the connection with two fingers as possible and pulling the connector out.
      • Moving the connector back and forth as you pull will make removal easier.
      댓글 쓰기
    4. Sharper Image iPulse SI325 Light Intensity Dial Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the two 11mm Phillips #1 screws attaching the small brown circuit board to the plastic case.
      • Also remove the four 11mm Phillips #1 screws attaching the motherboard to the plastic case.
      댓글 쓰기
    5. Sharper Image iPulse SI325 Light Intensity Dial Replacement: 8 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 Light Intensity Dial Replacement: 8 단계, 이미지 2개 중 2개
      • Lift up on both the motherboard and brown circuit board that contains the light intensity dial and turn the motherboard over.
      댓글 쓰기
    6. Sharper Image iPulse SI325 Light Intensity Dial Replacement: 9 단계, 이미지 3개 중 1개 Sharper Image iPulse SI325 Light Intensity Dial Replacement: 9 단계, 이미지 3개 중 2개 Sharper Image iPulse SI325 Light Intensity Dial Replacement: 9 단계, 이미지 3개 중 3개
      • Hold the brown circuit board with one hand and the light intensity dial with two fingers of your other hand and carefully pull them apart.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Melissa Pasa
회원 가입일: 10/13/13
701 평판
안내서 7개를 작성함
Cal Poly, Team 11-33, Amido Fall 2013 Cal Poly, Team 11-33, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G33
4 회원들
안내서 54개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 28
전체 시간: 650
