주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shoe Insole Repair
필요한 것
    1. Shoe Insole Repair, Shoe Insole Repair: 1 단계, 이미지 1개 중 1개
      • Collect everything you need for the repair.
      • A piece of foam from new shoe packaging is ideal because it matches the insole’s cushioning. If you don’t have foam, a thick old sock or piece of soft clothing works well too.
      댓글 쓰기
    2. Shoe Insole Repair: 2 단계, 이미지 2개 중 1개 Shoe Insole Repair: 2 단계, 이미지 2개 중 2개
      • Place your insole on a flat surface. Use a marker or pen to trace the outline of the hole (or worn spot) onto your scrap foam or fabric.
      • Trace slightly larger than the hole so the patch overlaps the edges a little for a stronger repair.
      댓글 쓰기
    3. Shoe Insole Repair: 3 단계, 이미지 3개 중 1개 Shoe Insole Repair: 3 단계, 이미지 3개 중 2개 Shoe Insole Repair: 3 단계, 이미지 3개 중 3개
      • Carefully cut along your traced line with scissors. Test the patch in the hole; it should sit flush or slightly above the insole. Trim as needed until it fits snugly without gaps.
      • If the hole goes all the way through the insole, cut a second identical patch to layer underneath for extra support.
      댓글 쓰기
    4. Shoe Insole Repair: 4 단계, 이미지 3개 중 1개 Shoe Insole Repair: 4 단계, 이미지 3개 중 2개 Shoe Insole Repair: 4 단계, 이미지 3개 중 3개
      • Apply a thin layer of glue all around the edges of the patch. Press it firmly into the hole so the glue makes good contact with the surrounding insole. Use small pieces of tape to hold the patch securely while the glue dries.
      • Usually 10–30 minutes, or follow your glue’s drying instructions).
      댓글 쓰기
    5. Shoe Insole Repair: 5 단계, 이미지 2개 중 1개 Shoe Insole Repair: 5 단계, 이미지 2개 중 2개
      • Once the glue is fully dry, remove the tape. Press on the patch and test how it feels.
      • If it’s loose or there are gaps, apply a bit more glue around the edges and tape it down again to dry.
      댓글 쓰기
    6. Shoe Insole Repair: 6 단계, 이미지 1개 중 1개
      • This step is optional. For a longer-lasting and more comfortable repair, cut a thin piece of fabric (from an old sock or t-shirt) slightly larger than the patch. Apply glue to the back of the fabric and press it smoothly over the repaired area. This creates a softer surface for your foot and helps the patch hold up better over time.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Claire Vest
회원 가입일: 03/14/26
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 32
지난 30일: 179
전체 시간: 458
