주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shop-Vac MC150A Motor Replacement
필요한 것
    1. Shop-Vac MC150A Motor Replacement, Unlatch the power unit assembly: 1 단계, 이미지 1개 중 1개
      • Before you begin, make sure to switch off the device and unplug it from the outlet.
      • Unlatch the two side clips securing the power unit assembly to the tank.
      • Remove the power unit assembly from the tank assembly.
      댓글 쓰기
    2. Shop-Vac MC150A Motor Replacement, Remove the top cover: 2 단계, 이미지 2개 중 1개 Shop-Vac MC150A Motor Replacement, Remove the top cover: 2 단계, 이미지 2개 중 2개
      • Use a 3.5 mm hex key to remove the three screws securing the top cover.
      • Remove the top cover.
      댓글 쓰기
    3. Shop-Vac MC150A Motor Replacement: 3 단계, 이미지 1개 중 1개
      • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
      댓글 쓰기
    4. Shop-Vac MC150A Motor Replacement: 4 단계, 이미지 1개 중 1개
      • Separate the power unit assembly from the cover.
      댓글 쓰기
    1. Shop-Vac MC150A Motor Replacement, Disconnect the switch: 5 단계, 이미지 3개 중 1개 Shop-Vac MC150A Motor Replacement, Disconnect the switch: 5 단계, 이미지 3개 중 2개 Shop-Vac MC150A Motor Replacement, Disconnect the switch: 5 단계, 이미지 3개 중 3개
      • Pull out and disconnect the four spade connectors from the switch module.
      • During reassembly, use the last image as a reference for how to connect the wires.
      댓글 쓰기
    2. Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: 6 단계, 이미지 2개 중 1개 Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: 6 단계, 이미지 2개 중 2개
      • Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
      댓글 쓰기
    3. Shop-Vac MC150A Motor Replacement: 7 단계, 이미지 2개 중 1개 Shop-Vac MC150A Motor Replacement: 7 단계, 이미지 2개 중 2개
      • During reassembly, be sure to reattach the green ground wire clip to the bracket.
      댓글 쓰기
    4. Shop-Vac MC150A Motor Replacement: 8 단계, 이미지 1개 중 1개
      • Separate the clip from the green wire and transfer it to the replacement motor.
      댓글 쓰기
    1. Shop-Vac MC150A Motor Replacement, Motor: 9 단계, 이미지 2개 중 1개 Shop-Vac MC150A Motor Replacement, Motor: 9 단계, 이미지 2개 중 2개
      • Remove the motor bracket.
      댓글 쓰기
    2. Shop-Vac MC150A Motor Replacement: 10 단계, 이미지 1개 중 1개
      • Turn the part over to the other side.
      • Use the socket wrench remove the bolt securing the aluminum plate.
      댓글 쓰기
    3. Shop-Vac MC150A Motor Replacement: 11 단계, 이미지 1개 중 1개
      • Unscrew the two Phillips head screws holding the cover to the motor.
      • After removing the cover to the motor, you can replace the motor.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Ngunlian
회원 가입일: 02/08/16
756 평판
안내서 5개를 작성함
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G2
5 회원들
안내서 18개를 작성함
2가이드 댓글
Where do I buy a new motor?????
Gerald Mikel - 답글 공유
Yeah that's what we all would like to know, removing is the easy part
Junkyard_Boxer - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 47
지난 30일: 242
전체 시간: 32,376
