주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shure SM58 Capsule Installation Replacement
필요한 것
    1. Shure SM58 Capsule Installation Replacement, Collar: 1 단계, 이미지 3개 중 1개 Shure SM58 Capsule Installation Replacement, Collar: 1 단계, 이미지 3개 중 2개 Shure SM58 Capsule Installation Replacement, Collar: 1 단계, 이미지 3개 중 3개
      • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
      • Be careful to not pull on the collar or you may rip the wires from the faceplate.
      댓글 쓰기
    1. Shure SM58 Capsule Installation Replacement, Faceplate: 2 단계, 이미지 1개 중 1개
      • Remove the yellow and green wires from the face plate.
      • Note which side the yellow and green wires connect to.
      댓글 쓰기
    2. Shure SM58 Capsule Installation Replacement: 3 단계, 이미지 2개 중 1개 Shure SM58 Capsule Installation Replacement: 3 단계, 이미지 2개 중 2개
      • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
      • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
      댓글 쓰기
    3. Shure SM58 Capsule Installation Replacement: 4 단계, 이미지 2개 중 1개 Shure SM58 Capsule Installation Replacement: 4 단계, 이미지 2개 중 2개
      • Slide the face plate over the connector.
      댓글 쓰기
    1. Shure SM58 Capsule Installation Replacement, Capsule Installation: 5 단계, 이미지 2개 중 1개 Shure SM58 Capsule Installation Replacement, Capsule Installation: 5 단계, 이미지 2개 중 2개
      • Using an adjustable wrench, remove the nut and the washer behind the face plate by twisting the nut counterclockwise.
      댓글 쓰기
    2. Shure SM58 Capsule Installation Replacement: 6 단계, 이미지 1개 중 1개
      • Hold the body of the microphone, right below the grille, in one hand. Using your other hand, rotate the grille clockwise.
      댓글 쓰기
    3. Shure SM58 Capsule Installation Replacement: 7 단계, 이미지 1개 중 1개
      • Slide the grille off the top of the microphone once it is all the way loosened.
      댓글 쓰기
    4. Shure SM58 Capsule Installation Replacement: 8 단계, 이미지 3개 중 1개 Shure SM58 Capsule Installation Replacement: 8 단계, 이미지 3개 중 2개 Shure SM58 Capsule Installation Replacement: 8 단계, 이미지 3개 중 3개
      • Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
      • Slowly, pull upward while twisting the black plastic piece clockwise.
      • Be careful not to scratch the copper microphone capsule. Another face plate may fall out when removing capsule.
      • Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
      댓글 쓰기
결론
Once installed, reassemble the microphone following the steps in reverse.
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
nat coll
회원 가입일: 09/27/12
859 평판
안내서 14개를 작성함
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 88개를 작성함
5가이드 댓글
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
Eanoid - 답글 공유
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
Daniel Berger - 답글 공유
Somehow the grill got really stuck and I want to replace it. It it screwed or is it as you've said - slidable?
arnold - 답글 공유
You can unscrew just the grill.
Burke McQuinn - 답글 공유
Hi, a bit unrelated but I accidentally twisted the black plastic piece slightly while everything was still intact. I turned it back though, did I damage the SM58 in any way?
Emje De - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 51
지난 30일: 242
전체 시간: 45,400
