주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Side Panel Removal
필요한 것
  1. Side Panel Removal, Side Panel Removal: 1 단계, 이미지 3개 중 1개 Side Panel Removal, Side Panel Removal: 1 단계, 이미지 3개 중 2개 Side Panel Removal, Side Panel Removal: 1 단계, 이미지 3개 중 3개
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
    댓글 쓰기
  2. Side Panel Removal: 2 단계, 이미지 3개 중 1개 Side Panel Removal: 2 단계, 이미지 3개 중 2개 Side Panel Removal: 2 단계, 이미지 3개 중 3개
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Oli
회원 가입일: 01/03/14
1,577 평판
안내서 4개를 작성함
1가이드 댓글
I took it out, but now it’s not going all the way in
Ali - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 33
지난 30일: 92
전체 시간: 3,712
