주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Siemens A56 LCD Display Replacement
필요한 것
    1. Siemens A56 LCD Display Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Press down on the grooved area firmly in the direction of arrow #1.
      • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
      • Photos taken from: http://theinformr.com/uploads/manuals/si...
      댓글 쓰기
    2. Siemens A56 LCD Display Replacement: 2 단계, 이미지 1개 중 1개
      • Turn off the phone before removing the battery to avoid damage.
      • Press the latch on the battery in the direction of arrow #3.
      • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
      • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
      댓글 쓰기
    1. Siemens A56 LCD Display Replacement, Front Plate: 3 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement, Front Plate: 3 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement, Front Plate: 3 단계, 이미지 3개 중 3개
      • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
      • Pull up on the two plastic clips at the top of the phone.
      • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
      댓글 쓰기
    1. Siemens A56 LCD Display Replacement, Back Plastic Cover: 4 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement, Back Plastic Cover: 4 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement, Back Plastic Cover: 4 단계, 이미지 3개 중 3개
      • Along the side of the metal frame of the phone, locate the six screws.
      • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
      • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
      댓글 쓰기
    2. Siemens A56 LCD Display Replacement: 5 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement: 5 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement: 5 단계, 이미지 3개 중 3개
      • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
      • Gently remove the motherboard from the back plastic cover.
      • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
      댓글 쓰기
    1. Siemens A56 LCD Display Replacement, Motherboard Metal Frame: 6 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement, Motherboard Metal Frame: 6 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement, Motherboard Metal Frame: 6 단계, 이미지 3개 중 3개
      • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
      • Once loosened, the metal frame should be able to be lifted from the motherboard.
      댓글 쓰기
    1. Siemens A56 LCD Display Replacement, Motherboard from Keypad Interface: 7 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement, Motherboard from Keypad Interface: 7 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement, Motherboard from Keypad Interface: 7 단계, 이미지 3개 중 3개
      • Insert the fine-tipped spudger in between the motherboard and the keypad interface.
      • Gently work the spudger across the length of the motherboard.
      • An adhesive exists between the motherboard and the keypad interface.
      • Once loosened, the motherboard should easily separate from the keypad interface.
      댓글 쓰기
    1. Siemens A56 LCD Display Replacement, LCD Display: 8 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement, LCD Display: 8 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement, LCD Display: 8 단계, 이미지 3개 중 3개
      • Locate the LCD Display.
      • Above the display, there are two metal clasps. Bend the clasps until they are straight.
      댓글 쓰기
    2. Siemens A56 LCD Display Replacement: 9 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement: 9 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement: 9 단계, 이미지 3개 중 3개
      • On the sides of the display there are two more metal clasps.
      • Gently bend the clasp so that the metal display frame becomes loose from the screen.
      • Flip the device over and gently bend the other clasp so that the metal display frame becomes loose from the screen.
      댓글 쓰기
    3. Siemens A56 LCD Display Replacement: 10 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement: 10 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement: 10 단계, 이미지 3개 중 3개
      • Place the device so the display screen is facing up.
      • On the bottom of the display frame, locate two plastic rivets.
      • Remove these rivets by scraping with the plastic opening tool or a fingernail.
      • Once removed, the plastic rivets can only be reapplied with a heat gun.
      댓글 쓰기
    4. Siemens A56 LCD Display Replacement: 11 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement: 11 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement: 11 단계, 이미지 3개 중 3개
      • To remove the metal frame, gently grab the frame and lift from the keypad interface.
      • If the frame cannot be easily removed. ensure that the metal clasps from steps 8 and 9 have been sufficiently bent to allow removal.
      댓글 쓰기
    5. Siemens A56 LCD Display Replacement: 12 단계, 이미지 3개 중 1개 Siemens A56 LCD Display Replacement: 12 단계, 이미지 3개 중 2개 Siemens A56 LCD Display Replacement: 12 단계, 이미지 3개 중 3개
      • Once the metal frame is removed, the LCD display should fall from the keypad interface when tilted.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Joseph Casey
회원 가입일: 03/26/14
414 평판
안내서 4개를 작성함
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 회원
CLEM-BENSON-S14S6G6
4 회원들
안내서 63개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 32
전체 시간: 1,202
