주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sirius Stiletto 100 Volume Button Replacement
필요한 것
    1. Sirius Stiletto 100 Volume Button Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 Sirius Stiletto 100 Volume Button Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
      • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
      댓글 쓰기
    2. Sirius Stiletto 100 Volume Button Replacement: 2 단계, 이미지 2개 중 1개 Sirius Stiletto 100 Volume Button Replacement: 2 단계, 이미지 2개 중 2개
      • Use a Philip's head screw driver to remove the screws from the case.
      • Place the screws in a small container to avoid losing them.
      댓글 쓰기
    3. Sirius Stiletto 100 Volume Button Replacement: 3 단계, 이미지 3개 중 1개 Sirius Stiletto 100 Volume Button Replacement: 3 단계, 이미지 3개 중 2개 Sirius Stiletto 100 Volume Button Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the front cover.
      • First, insert a small pry bar where the black front cover and white back cover meet.
      • Begin prying the black plastic up, slowing moving around to the bottom and other side.
      • At an angle, carefully pull up on the front cover separate the two pieces.
      • Excellent! Now you have removed the front cover!
      댓글 쓰기
    1. Sirius Stiletto 100 Volume Button Replacement, Circuit Board: 4 단계, 이미지 1개 중 1개
      • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
      댓글 쓰기
    2. Sirius Stiletto 100 Volume Button Replacement: 5 단계, 이미지 2개 중 1개 Sirius Stiletto 100 Volume Button Replacement: 5 단계, 이미지 2개 중 2개
      • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
      댓글 쓰기
    3. Sirius Stiletto 100 Volume Button Replacement: 6 단계, 이미지 1개 중 1개
      • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
      댓글 쓰기
    1. Sirius Stiletto 100 Volume Button Replacement, Volume Button: 7 단계, 이미지 1개 중 1개
      • Locate the volume button on the side of the device. The volume button is indicated with an orange rectangle in the photograph.
      댓글 쓰기
    2. Sirius Stiletto 100 Volume Button Replacement: 8 단계, 이미지 1개 중 1개
      • Turn the device so that you are looking at the other side of the volume button (from "inside" the device).
      댓글 쓰기
    3. Sirius Stiletto 100 Volume Button Replacement: 9 단계, 이미지 1개 중 1개
      • Push on the volume button with both of your thumbs. Wiggle the volume button back and forth as you push upwards.
      • The volume button will pop out.
      댓글 쓰기
    4. Sirius Stiletto 100 Volume Button Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the volume button from the device.
      댓글 쓰기
    5. Sirius Stiletto 100 Volume Button Replacement: 11 단계, 이미지 1개 중 1개
      • Slide the new volume button into the slot for the volume button.
      • Make sure that the volume button is oriented correctly. An easy way to check this is to hold the volume button in place and look at the side of the device.
      댓글 쓰기
    6. Sirius Stiletto 100 Volume Button Replacement: 12 단계, 이미지 1개 중 1개
      • Push down on the volume button to snap it back into the case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Morgan McDougald
회원 가입일: 03/09/12
89 평판
안내서 3개를 작성함
Clemson, Team 2-1, Benson Spring 2012 Clemson, Team 2-1, Benson Spring 2012 회원
CLEM-BENSON-S12S2G1
3 회원들
안내서 18개를 작성함
1가이드 댓글
Because of the difference between two people in the morning but I'm going&@6899!12;;....,
Rich Ridout - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 28
전체 시간: 1,734
