주요 콘텐츠로 건너뛰기
Skateboard Trucks Replacement
필요한 것
  1. Skateboard Trucks Replacement, Trucks: 1 단계, 이미지 2개 중 1개 Skateboard Trucks Replacement, Trucks: 1 단계, 이미지 2개 중 2개
    • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
    • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
  2. Skateboard Trucks Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
  3. Skateboard Trucks Replacement: 3 단계, 이미지 1개 중 1개
    • Hand tighten the nut hardware onto all four bolts.
  4. Skateboard Trucks Replacement: 4 단계, 이미지 1개 중 1개
    • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
    • Repeat steps 1 - 6 to install the second truck.
결론
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Cameron Nye
회원 가입일: 10/03/12
79 평판
안내서 1개를 작성함
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 회원
CPSU-REGAN-F12S6G32
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 19
전체 시간: 13,585
