주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Skateboard Wheel Replacement
필요한 것
    1. Skateboard Wheel Replacement, The skate board fix up: 1 단계, 이미지 1개 중 1개
      • With a 13mm wrench, remove the axle nut located in the center of the wheel.
      • Set the axle nut aside, and remove the wheel.
      댓글 쓰기
    2. Skateboard Wheel Replacement, Remove the Bearings: 2 단계, 이미지 1개 중 1개
      • Position the wheel at the end of the axle.
      • To remove the bearings, gently pry the wheel at a downward angle.
      • Perform this prying process on both sides of the wheel.
      • A bearing spacer should fall out once the bearings are removed.
      댓글 쓰기
    3. Skateboard Wheel Replacement: 3 단계, 이미지 1개 중 1개
      • Position the new wheel on a flat surface.
      • Press the bearing into the hole of the new wheel.
      • Press firmly until the bearing snaps into place. The bearing's outside edges should be flush with the inside bottom edge of the wheel.
      댓글 쓰기
    4. Skateboard Wheel Replacement: 4 단계, 이미지 1개 중 1개
      • Flip the wheel over.
      • Insert the bearing spacer into the back the wheel.
      댓글 쓰기
    5. Skateboard Wheel Replacement: 5 단계, 이미지 1개 중 1개
      • Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
      • With the bearings in place, the wheel can be placed on the axle.
      댓글 쓰기
    6. Skateboard Wheel Replacement: 6 단계, 이미지 1개 중 1개
      • Slide one washer onto the axle.
      댓글 쓰기
    7. Skateboard Wheel Replacement: 7 단계, 이미지 1개 중 1개
      • Slide the wheel onto the axle.
      • The axle should go through both bearings and the bearing spacer.
      댓글 쓰기
    8. Skateboard Wheel Replacement: 8 단계, 이미지 1개 중 1개
      • Slide the second washer onto the axle on the outside of the wheel.
      댓글 쓰기
    9. Skateboard Wheel Replacement: 9 단계, 이미지 1개 중 1개
      • Tighten the axle nut firmly.
      • Do not over tighten. The wheel should spin freely.
      • Repeat steps 1-9 for the remaining wheels.
      댓글 쓰기
결론
Once your wheels are installed, you can ride your skateboard. If you feel your wheels hitting the bottom of your deck when you are turning, you may want to refer to the Wheel Bite Prevention guide.
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Jared Stine
회원 가입일: 10/05/12
800 평판
안내서 3개를 작성함
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 회원
CPSU-REGAN-F12S6G32
5 회원들
안내서 6개를 작성함
3가이드 댓글
Very helpful - just got a skateboard for my son and used this guide to adjust two wheels.
emvxl - 답글 공유
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Kenzie Peck - 답글 공유
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
Kelly Brien - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 68
전체 시간: 79,609
