주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Skullcandy Air Raid Buttons Replacement
필요한 것
  1. Skullcandy Air Raid Buttons Replacement, Rubber Cover: 1 단계, 이미지 1개 중 1개
    • Starting with the corners, gently pull the rubber cover off of the device.
    댓글 쓰기
  2. Skullcandy Air Raid Buttons Replacement, Handle: 2 단계, 이미지 1개 중 1개
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
    댓글 쓰기
  3. Skullcandy Air Raid Buttons Replacement, Front Plate: 3 단계, 이미지 1개 중 1개
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
    댓글 쓰기
  4. Skullcandy Air Raid Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
    댓글 쓰기
  5. Skullcandy Air Raid Buttons Replacement, Control Buttons: 5 단계, 이미지 2개 중 1개 Skullcandy Air Raid Buttons Replacement, Control Buttons: 5 단계, 이미지 2개 중 2개
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, specifically above and below the volume buttons.
    • Lift the button panel.
    댓글 쓰기
  6. Skullcandy Air Raid Buttons Replacement, Button Motherboard: 6 단계, 이미지 1개 중 1개
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
    댓글 쓰기
  7. Skullcandy Air Raid Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, pry up on the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
    댓글 쓰기
  8. Skullcandy Air Raid Buttons Replacement, Ribbon Cable: 8 단계, 이미지 1개 중 1개
    • First, pull on the black attachment to disconnect it from the metal piece.
    • Release the cable from the back of the motherboard.
    • The black attachment is a part of the connector, not the blue ribbon cable. It will not disconnect from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sasha Nevin
회원 가입일: 01/13/15
257 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 23
전체 시간: 1,630
