주요 콘텐츠로 건너뛰기
Skullcandy Crusher Wireless Earpiece Speaker Replacement
필요한 것
  1. Skullcandy Crusher Wireless Earpiece Speaker Replacement, Ear Cushion: 1 단계, 이미지 1/2 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Ear Cushion: 1 단계, 이미지 2/2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Earpiece Speaker Replacement: 2 단계, 이미지 1/2 Skullcandy Crusher Wireless Earpiece Speaker Replacement: 2 단계, 이미지 2/2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Earpiece Speaker Replacement: 3 단계, 이미지 1/1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Earpiece Speaker Replacement, USB Connector: 4 단계, 이미지 1/2 Skullcandy Crusher Wireless Earpiece Speaker Replacement, USB Connector: 4 단계, 이미지 2/2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion.
  5. Skullcandy Crusher Wireless Earpiece Speaker Replacement: 5 단계, 이미지 1/3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: 5 단계, 이미지 2/3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: 5 단계, 이미지 3/3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Earpiece Speaker Replacement: 6 단계, 이미지 1/2 Skullcandy Crusher Wireless Earpiece Speaker Replacement: 6 단계, 이미지 2/2
    • Separate the headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Earpiece Speaker Replacement: 7 단계, 이미지 1/1
    • Inspect the USB port and ensure that it is connected correctly. If necessary, desolder the USB port and replace it with the new port.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
  8. Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: 8 단계, 이미지 1/3 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: 8 단계, 이미지 2/3 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: 8 단계, 이미지 3/3
    • Remove four 4 mm Phillips #1 screws that connect the motherboard with the plastic frame.
  9. Skullcandy Crusher Wireless Earpiece Speaker Replacement: 9 단계, 이미지 1/3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: 9 단계, 이미지 2/3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: 9 단계, 이미지 3/3
    • Remove three 4 mm Phillips #1 screws that connect the bass speaker to the plastic frame.
  10. Skullcandy Crusher Wireless Earpiece Speaker Replacement: 10 단계, 이미지 1/3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: 10 단계, 이미지 2/3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: 10 단계, 이미지 3/3
    • Move the motherboard away from the plastic frame.
    • Desolder two cables to replace the speaker and bass component.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Val
회원 가입일: 03/31/22
1,104 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 UMass Dartmouth, Team 1-33, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22S1G33
1 회원
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 20
30일 전: 116
전체 시간: 2,500
