소개
Use this guide to replace the earpiece speaker in a Skullcandy Crusher Wireless headphones. Replacement speakers can be bought online.
Follow this replacement guide if the earpiece speaker has stopped working and you've ruled out other sources of the problem (or maybe you just want to see the internal components of your Skullcandy Crusher Wireless). See our Troubleshooting page for more information on what could be causing the sound issues.
Also, for more information about soldering and desoldering, please use this guide.
필요한 것
Take your headphones and hold them upside down for better control with your hands.
Remove three 12 mm Phillips #1 screws located underneath the left ear cushion.
Remove four 4 mm Phillips #1 screws that connect the motherboard with the plastic frame.
다른 한 분이 해당 안내서를 완성하였습니다.
