주요 콘텐츠로 건너뛰기
Skullcandy Hesh 3 Charging Port Replacement
필요한 것
  1. Skullcandy Hesh 3 Charging Port Replacement, Charging Port: 1 단계, 이미지 1/3 Skullcandy Hesh 3 Charging Port Replacement, Charging Port: 1 단계, 이미지 2/3 Skullcandy Hesh 3 Charging Port Replacement, Charging Port: 1 단계, 이미지 3/3
    • Start by removing the earmuffs on the speaker side with the charging port. Gently pull from any point of the ear cushion, while also holding on to the base of the speaker.
    • Use a Phillips #00 screwdriver to remove all four 4.0 mm screws securing the faceplate.
    • Remove the faceplate gently without pulling off the wires attached to the speaker and faceplate.
  2. Skullcandy Hesh 3 Charging Port Replacement: 2 단계, 이미지 1/2 Skullcandy Hesh 3 Charging Port Replacement: 2 단계, 이미지 2/2
    • Use a soldering iron to heat up the solder at the points where the red, yellow, and black battery cables connect until they detach from the board.
    • Detach the connector on the side of the headphone cup to disconnect the red and black cables (next to the battery cables) from the headphones.
    • Slide the motherboard out of the headphone cup and flip it over.
    • Careful that you don't rip any of the remaining soldered connections (like the speaker connections for example.)
  3. Skullcandy Hesh 3 Charging Port Replacement: 3 단계, 이미지 1/2 Skullcandy Hesh 3 Charging Port Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to hold the charging port in place, and use a soldering iron to desolder the four soldering points.
    • With tweezers, gently remove the charging port.
    • If there is any resistance, stop immediately to not cause any damage to the motherboard. You may have missed a solder point.
    • Before attaching the new charging port, make sure to clean the previous spot, and remove any residue of adhesive using a connector conditioner and detailing brush.
결론
Emma Lyman
회원 가입일: 01/17/23
385 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 159
