주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Slingbox 500 Motherboard Replacement
필요한 것
    1. Slingbox 500 Motherboard Replacement, Top Cover: 1 단계, 이미지 1개 중 1개
      • Remove the sticker on the back of the Slingbox that covers the rear screws using a spudger.
      댓글 쓰기
    2. Slingbox 500 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Slingbox 500 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the seven 7.9 mm rear screws from the device using a Phillips #1 screwdriver.
      • Flip your Slingbox so the bottom is facing upwards.
      • Remove the four 7.9 mm screws using a Phillips #1 screwdriver.
      • You may have rubber feet on the bottom of your Slingbox. If you do, just gently remove them with your hands and set them aside to put back on later.
      댓글 쓰기
    3. Slingbox 500 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Slingbox 500 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Slingbox 500 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the upper section of the case by rotating your Slingbox to view the back and lifting up on the higher corner.
      • Use the opening tool to disconnect the small clips in the front.
      • These may require some minor force to disconnect.
      • Remove the entire top of the Slingbox and set it aside.
      댓글 쓰기
    1. Slingbox 500 Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Slingbox 500 Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
      • Remove five 9.5 mm screws from the motherboard using a Phillips #1 screwdriver.
      • Push down firmly on the screws as to not strip them when removing them as they may not spin easily at first.
      • After removing the screws the two metal tabs on either side will be free. Make sure to not bend them or accidentally damage the wires while doing further dissasembly.
      댓글 쓰기
    2. Slingbox 500 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the motherboard from the lower case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
David Sullivan
회원 가입일: 10/18/21
365 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-3, Simcock Fall 2021 UMass Dartmouth, Team 1-3, Simcock Fall 2021 회원
UMASSD-SIMCOCK-F21S1G3
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 17
전체 시간: 461
