주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Smart Keyboard 수리는 저희 서비스 설명서를 사용하십시오.
  1. Smart Keyboard Teardown, Smart Keyboard Teardown: 1 단계, 이미지 1/3 Smart Keyboard Teardown, Smart Keyboard Teardown: 1 단계, 이미지 2/3 Smart Keyboard Teardown, Smart Keyboard Teardown: 1 단계, 이미지 3/3
    • Check out these smart specs!
    • Smart Connector for power and data connection
    • 64 Key, QWERTY keyboard
    • Water and stain-resistant
  2. Smart Keyboard Teardown: 2 단계, 이미지 1/3 Smart Keyboard Teardown: 2 단계, 이미지 2/3 Smart Keyboard Teardown: 2 단계, 이미지 3/3
    • The bottom flap is home to all the regular suspects—regulatory markings, country of origin, and a new model number: A1636.
    • Hamburger? Hot Dog? With all these folds, the Smart Keyboard definitely breaks the record for the most confusing combination keyboard/case ever.
    • Seriously, this thing has so many sections, Apple even included a handy "guide" on how to fold it correctly.
    • We finally get the Smart Keyboard to bend to our will and lay mostly flat (not taking into account the 4 mm depth of each individual key). It looks like the perfect symmetry we found in the iPad Pro doesn't carry over to its accessories.
  3. Smart Keyboard Teardown: 3 단계, 이미지 1/3 Smart Keyboard Teardown: 3 단계, 이미지 2/3 Smart Keyboard Teardown: 3 단계, 이미지 3/3
    • On the left, an iPad Pro with the Smart Keyboard. On the right, a Surface Pro 4. We're pretty sure anyway, the differences are pretty slight at first glance.
    • The most marked difference between the key layouts is of course the Surface's trackpad. iPads just want to watch the world burn...
    • We know, iOS doesn't support any mouse-type input, so a trackpad here wouldn't really work. Still, with the rapidly growing number of iPad applications, we are hopeful...
    • The Smart Keyboard features some iOS hallmarks, like the keyboard swapping globe button, and rounder key edges.
    • However the iPad Pro also seems to be taking some notes from its notebook cousins, the Smart Keyboard has control, option, and command keys.
  4. Smart Keyboard Teardown: 4 단계, 이미지 1/3 Smart Keyboard Teardown: 4 단계, 이미지 2/3 Smart Keyboard Teardown: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Precision Utility Knife
    구매
    • In order to make the Smart Keyboard water and stain-resistant, Apple encapsulated the entire accessory inside some high tech fabric.
    • Finding no viable entry points, we turn to our Tech Knife for sage wisdom.
    • We slice and dice the microfiber lining of the keyboard as we burrow our way towards victory.
    • At this point, it's readily apparent that this teardown is an irreversible process.
  5. Smart Keyboard Teardown: 5 단계, 이미지 1/3 Smart Keyboard Teardown: 5 단계, 이미지 2/3 Smart Keyboard Teardown: 5 단계, 이미지 3/3
    • We peel up the top layer of mysterious fabric (we think it's nylon—our teardown engineer notes that it feels like a windbreaker) to find blank keys.
    • Perhaps Jony Ive was worried about your keyboard getting get too cold?
    • Moving past the fabric, we begin prying out the individual keys and get our first glance at the dome switches underneath.
    • As Apple stated during their keynote, these switches are the same as those found in the 2015 Retina MacBook.
    • One design choice we like is the placement of a stiffening weight in the spacebar.
    • The addition of this bar means the spacebar key can register a push no matter where you tap on it. No wobbly spacebar woes here.
  6. Smart Keyboard Teardown: 6 단계, 이미지 1/3 Smart Keyboard Teardown: 6 단계, 이미지 2/3 Smart Keyboard Teardown: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $74.95
    구매
    • We call upon our iOpener to heat the microfiber lining, allowing us to delve further into the multiple layers of the Smart Keyboard cover panel.
    • We're starting to feel like archeologists, digging through the ages...
    • Underneath the soft display cover we find... nothing really.
    • Time for a brief message from our sponsors: We're excited to announce that we've just released a completely redesigned Pro Tech Toolkit, complete with all of the tools you need, and none that you don't.
    • With this tough plastic layer blocking further keyboard inroads, we're going to need one of those tools...
  7. Smart Keyboard Teardown: 7 단계, 이미지 1/3 Smart Keyboard Teardown: 7 단계, 이미지 2/3 Smart Keyboard Teardown: 7 단계, 이미지 3/3
    • Like a plastic opening pick.
    • We crack open the clam and the pearls keycaps come cascading out.
    • We now have the pleasure of viewing the entire underlying circuit board, replete with 64 dome switches.
    • But not much else, no LEDs, or batteries or fancy fans needed here!
  8. Smart Keyboard Teardown: 8 단계, 이미지 1/2 Smart Keyboard Teardown: 8 단계, 이미지 2/2
    • Another one bites the dust. We pull the keycap frame away for a closer look.
    • There are some interesting intestinal squiggles in this plastic frame, what's up with that?
    • Closer inspection shows these channels lead to tiny vents at the top of the keyboard.
    • We assume this keeps the Smart Keyboard from becoming a pressurized balloon every time a key is depressed.
    • Let's hope these holes don't let water in...
  9. Smart Keyboard Teardown: 9 단계, 이미지 1/3 Smart Keyboard Teardown: 9 단계, 이미지 2/3 Smart Keyboard Teardown: 9 단계, 이미지 3/3
    • Time to peel up yet another layer! In fact, it's that tough plastic backing we encountered earlier. It's aggressively glued, so we aggressively, well, ripped in in half...
    • Finally, the true keyboard is revealed—a plane of switches and chips!
    • The brains of the operation is Apple's latest go-to microcontroller for peripheral input devices:
    • STMicroelectronics STM32F103VB 72 MHz 32-bit RISC ARM Cortex-M3
    • Macronix MX25L4006EZUI-12G 4 Mb serial flash memory
  10. Smart Keyboard Teardown: 10 단계, 이미지 1/2 Smart Keyboard Teardown: 10 단계, 이미지 2/2
    • Peeling up the last of the Smart Keyboard's pelt reveals three interesting fabric strips.
    • Turns out, these are made of Apple's mysterious "conductive fabric." These connect the keyboard to the Smart Connector and allow for a "two‑way flow of power and data."
    • We're excited about this design feature, as these fabric strips should be more durable and fail-resistant than wires or traditional flex cables.
    • Apple even states "unlike traditional wires, the conductive fabric can withstand a lifetime of folding." Sweet!
  11. Smart Keyboard Teardown: 11 단계, 이미지 1/2 Smart Keyboard Teardown: 11 단계, 이미지 2/2
    • The Apple Smart Keyboard repairability 0 out of 10 (10 is easiest to repair):
    • While durable, the keyboard is impossible to open without damaging, meaning no internal components can be replaced without destroying the device.
Dante Mazzanti
회원 가입일: 07/13/15
36,177 평판
안내서 26개 작성하였습니다
댓글 34개
Another disposable product from Apple, if it ever goes wrong, that is =)
I am not surpised
Marhowl - 답글
I'm not either. I think that's going to be the norm (if not already) as devices become smaller and more complex. Not only from just Apple. I think the need to repair rather than replace will get less and less. I think this is a good thing, but it means scores like 'reparability' when reviewing or tearing down will continue to mean less and less to consumers over time. For myself, I already think it's a pretty glorified/meaningless statistic when reviewing a product I'm going to buy. As long as it's quality, and/or the manufacturer has a good warranty program, it's much more convenient for me to go that route. I can't remember the last time I needed to fix or pay to get fixed one of my electronic devices who isn't the manufacturer.
Nick - 답글
well, at some point of time maybe even you will grow up, take responsibility and try not to waste our beautiful planet with one-time, throw-away products..
Guido Boehm -
i suppose most products of companies have a limited warranty of, let's say, 2-3 years maximum.
what happens if after the warranty ends and the keyboard fails to work?
since you can't repair it your self, you can only use it as a placemat for your dinner.
alexios -
Guido, there's this thing called recycling, perhaps you've heard of it?
rpe33 -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 35
30일 전: 200
전체 시간: 103,767
