주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Smart Parts Ion Bolt Replacement
필요한 것
    1. Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: 1 단계, 이미지 3개 중 1개 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: 1 단계, 이미지 3개 중 2개 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: 1 단계, 이미지 3개 중 3개
      • Remove the air tank by rotating it counterclockwise.
      • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
      • The pressure gauge will indicate the leftover air in the gun.
      댓글 쓰기
    2. Smart Parts Ion Bolt Replacement: 2 단계, 이미지 2개 중 1개 Smart Parts Ion Bolt Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
      댓글 쓰기
    1. Smart Parts Ion Bolt Replacement, Smart Parts Ion De-Gassing: 3 단계, 이미지 1개 중 1개
      • Turn the gun on by pressing the power button until the red light blinks.
      • Turn vision mode off by pressing the power button again.
      • Red light should be flashing in a double blink sequence.
      댓글 쓰기
    2. Smart Parts Ion Bolt Replacement: 4 단계, 이미지 1개 중 1개
      • Pull the trigger to release the air in the gun.
      • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
      댓글 쓰기
    1. Smart Parts Ion Bolt Replacement, Grip: 5 단계, 이미지 1개 중 1개
      • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
      댓글 쓰기
    2. Smart Parts Ion Bolt Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the grip by sliding it towards the front of the gun.
      댓글 쓰기
    1. Smart Parts Ion Bolt Replacement, Battery: 7 단계, 이미지 2개 중 1개 Smart Parts Ion Bolt Replacement, Battery: 7 단계, 이미지 2개 중 2개
      • Remove the 9V battery by unsnapping it.
      댓글 쓰기
    1. Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: 8 단계, 이미지 3개 중 1개 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: 8 단계, 이미지 3개 중 2개 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: 8 단계, 이미지 3개 중 3개
      • Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
      댓글 쓰기
    2. Smart Parts Ion Bolt Replacement: 9 단계, 이미지 2개 중 1개 Smart Parts Ion Bolt Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the 12 mm screw on the top of the grip frame using a 3/32" Allen wrench.
      댓글 쓰기
    3. Smart Parts Ion Bolt Replacement: 10 단계, 이미지 1개 중 1개
      • Separate the gun's body from the frame by gently pulling them in opposite directions.
      댓글 쓰기
    4. Smart Parts Ion Bolt Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the 1-1/4" screw that's attached to the blue tube above the front grip using a 3/32" Allen Wrench.
      댓글 쓰기
    1. Smart Parts Ion Bolt Replacement, Removing the Solenoid from the Body: 12 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
      • Another small tool or your fingers will work for this.
      댓글 쓰기
    2. Smart Parts Ion Bolt Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the two 1-1/4" screws on either side of the circuit board using a 3/32" allen wrench.
      댓글 쓰기
    3. Smart Parts Ion Bolt Replacement: 14 단계, 이미지 1개 중 1개
      • Separate the solenoid from the gun's body by gently pulling it upwards.
      댓글 쓰기
    4. Smart Parts Ion Bolt Replacement: 15 단계, 이미지 1개 중 1개
      • Slide the metal body out of the plastic shell by holding one in each hand and gently pulling apart.
      댓글 쓰기
    1. Smart Parts Ion Bolt Replacement, Bolt: 16 단계, 이미지 2개 중 1개 Smart Parts Ion Bolt Replacement, Bolt: 16 단계, 이미지 2개 중 2개
      • Separate the front body breach from the fire chamber by rotating the breach counterclockwise.
      댓글 쓰기
    2. Smart Parts Ion Bolt Replacement: 17 단계, 이미지 1개 중 1개
      • Remove the bolt from the front body breach by gently pulling on the bolt.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Shane Villalpando
회원 가입일: 02/02/15
1,043 평판
안내서 10개를 작성함
Cal Poly, Team 8-42, Amido Winter 2015 Cal Poly, Team 8-42, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G42
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 33
전체 시간: 3,272
