주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Snapfon ez One SIM Card Replacement
필요한 것
  1. Snapfon ez One SIM Card Replacement, Remove the battery cover: 1 단계, 이미지 1개 중 1개
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
    댓글 쓰기
  2. Snapfon ez One SIM Card Replacement, Remove the battery: 2 단계, 이미지 1개 중 1개
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
    댓글 쓰기
  3. Snapfon ez One SIM Card Replacement, SIM Card: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the tweezers,if needed, to grasp the SIM card for removal. Apply a slight pulling tension and remove it from under the tabs as shown.
    댓글 쓰기
결론
To reinsert the SIM card or a new SIM card, position the card in the same orientation seen in the figure with the brass connections facing the phone while using thumb to apply a slight force until the card rest inside of the recessed holder. Make sure the brass contacts of the card and phone connect. Then follow the steps in reverse order to reassemble phone.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
John Bender
회원 가입일: 03/26/14
818 평판
안내서 8개를 작성함
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 회원
CLEM-BENSON-S14S6G5
3 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 51
전체 시간: 1,546
