주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Snowboard Binding Strap Replacement
필요한 것
    1. Snowboard Binding Strap Replacement, Binding: 1 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement, Binding: 1 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement, Binding: 1 단계, 이미지 3개 중 3개
      • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
      • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
      댓글 쓰기
    2. Snowboard Binding Strap Replacement: 2 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 2 단계, 이미지 2개 중 2개
      • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
      • The highback plate is the vertical support plate located on the heel side of the binding.
      댓글 쓰기
    3. Snowboard Binding Strap Replacement: 3 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 3 단계, 이미지 2개 중 2개
      • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
      댓글 쓰기
    4. Snowboard Binding Strap Replacement: 4 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement: 4 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement: 4 단계, 이미지 3개 중 3개
      • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
      • Lift or slide the binding off the board and set the screws aside.
      댓글 쓰기
    1. Snowboard Binding Strap Replacement, Binding Strap: 5 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement, Binding Strap: 5 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement, Binding Strap: 5 단계, 이미지 3개 중 3개
      • Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding.
      • Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
      댓글 쓰기
    2. Snowboard Binding Strap Replacement: 6 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 6 단계, 이미지 2개 중 2개
      • Unscrew the 10mm long thumb screw connecting the heel strap with its binding connector.
      • Pull the heel strap apart from its binding connector.
      댓글 쓰기
    3. Snowboard Binding Strap Replacement: 7 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement: 7 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement: 7 단계, 이미지 3개 중 3개
      • Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding.
      댓글 쓰기
    4. Snowboard Binding Strap Replacement: 8 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 8 단계, 이미지 2개 중 2개
      • Flip the binding so that the bottom is accessible.
      • Using your hands, pry off the plastic bottom covering starting at the toe end.
      • The bottom may still remain attached on the heel edge. There is no need to completely remove it.
      댓글 쓰기
    5. Snowboard Binding Strap Replacement: 9 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement: 9 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the corner foam coverings by grabbing one edge and lifting up.
      • Slide out the toe strap ladder.
      댓글 쓰기
    6. Snowboard Binding Strap Replacement: 10 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement: 10 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement: 10 단계, 이미지 3개 중 3개
      • Using a Phillips #2 screwdriver, unscrew the button head M4 x 10mm screw holding the toe strap with its connector.
      • Slide the toe strap off of the toe strap connector.
      댓글 쓰기
    7. Snowboard Binding Strap Replacement: 11 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 11 단계, 이미지 2개 중 2개
      • Turn the binding on its side and slide out the toe strap connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Robert Torres
회원 가입일: 01/14/14
214 평판
안내서 2개를 작성함
Cal Poly, Team 17-4, Forte Winter 2014 Cal Poly, Team 17-4, Forte Winter 2014 회원
CPSU-FORTE-W14S17G4
5 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 67
전체 시간: 51,396
