주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sonos Five Midwoofer Replacement
  1. Sonos Five Midwoofer Replacement, Grille Removal: 1 단계, 이미지 3개 중 1개 Sonos Five Midwoofer Replacement, Grille Removal: 1 단계, 이미지 3개 중 2개 Sonos Five Midwoofer Replacement, Grille Removal: 1 단계, 이미지 3개 중 3개
    • Use a thin guitar pick to carefully pry up the grille (photo one)
    • Ensure you position the pick to pry between the side of the case and the rubber grille frame; not the plastic mesh! (photos two and three)
    댓글 쓰기
  2. Sonos Five Midwoofer Replacement, Grill Removal Continued: 2 단계, 이미지 3개 중 1개 Sonos Five Midwoofer Replacement, Grill Removal Continued: 2 단계, 이미지 3개 중 2개 Sonos Five Midwoofer Replacement, Grill Removal Continued: 2 단계, 이미지 3개 중 3개
    • Continue to work your way around the sides until the grille is freed.
    • Make note of the red circled posts and their respective matching pins. They must be properly aligned when reinstalling the grille to prevent damage.
    댓글 쓰기
  3. Sonos Five Midwoofer Replacement, Left Midwoofer Removal: 3 단계, 이미지 3개 중 1개 Sonos Five Midwoofer Replacement, Left Midwoofer Removal: 3 단계, 이미지 3개 중 2개 Sonos Five Midwoofer Replacement, Left Midwoofer Removal: 3 단계, 이미지 3개 중 3개
    • Remove the four red circled Torx T20 screws securing the driver to the front panel.
    • Be sure to align the speaker properly with it's alignment posts during reinstallation (third photo, red arrow)
    댓글 쓰기
  4. Sonos Five Midwoofer Replacement, Disconnecting The Driver: 4 단계, 이미지 3개 중 1개 Sonos Five Midwoofer Replacement, Disconnecting The Driver: 4 단계, 이미지 3개 중 2개 Sonos Five Midwoofer Replacement, Disconnecting The Driver: 4 단계, 이미지 3개 중 3개
    • The insulated terminal simply pulls off to disconnect.
    • The non insulated terminal has a locking tab (red arrow, second photo). This tab that must be depressed with a small screwdriver to unlock it for removal.
    • The midwoofer may now be carefully removed from the supporting frame.
    댓글 쓰기
  5. Sonos Five Midwoofer Replacement, Center Midwoofer removal: 5 단계, 이미지 3개 중 1개 Sonos Five Midwoofer Replacement, Center Midwoofer removal: 5 단계, 이미지 3개 중 2개 Sonos Five Midwoofer Replacement, Center Midwoofer removal: 5 단계, 이미지 3개 중 3개
    • Raise the midwoofer out of the cabinet slightly to enable you to disconnect the terminals.
    • The center midwoofer driver wires are extremely short. Be Careful not to place too much tension on the wires. This takes two hands one holding the driver while you disconnect the terminals with the other.
    • Again, the insulated terminal simply slides off, but the non insulated terminal's locking tab must be depressed.
    댓글 쓰기
  6. Sonos Five Midwoofer Replacement, Right Midwoofer Removal: 6 단계, 이미지 3개 중 1개 Sonos Five Midwoofer Replacement, Right Midwoofer Removal: 6 단계, 이미지 3개 중 2개 Sonos Five Midwoofer Replacement, Right Midwoofer Removal: 6 단계, 이미지 3개 중 3개
    • Remove the four T20 screws securing the driver to the front panel
    • Lift the driver out of the cabinet.
    • The left noninsulated terminal again has a locking tab that must be depressed. (red arrow, photo two) The right terminal is simply pulled off.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nicholas Ouimet
회원 가입일: 10/16/09
3,700 평판
안내서 11개를 작성함
2가이드 댓글
Hola sabes donde podría comprar los parlantes tengo un somos five y están las tres bocinas reventadas
Ricardo.tranamil.h@gmail.com
Ricardo tranamil - 답글 공유
Hola nesecito comprar las bocinas de repuestos por favor
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 73
전체 시간: 3,487
