주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sonos One Tweeter Diaphragm Repair/ Replacement
필요한 것
    1. Sonos One Tweeter Diaphragm Repair/ Replacement, Protective Cover: 1 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement, Protective Cover: 1 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement, Protective Cover: 1 단계, 이미지 3개 중 3개
      • Disconnect all power cords.
      • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
      • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
      댓글 쓰기
    2. Sonos One Tweeter Diaphragm Repair/ Replacement: 2 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 2 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
      댓글 쓰기
    3. Sonos One Tweeter Diaphragm Repair/ Replacement: 3 단계, 이미지 2개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
      댓글 쓰기
    4. Sonos One Tweeter Diaphragm Repair/ Replacement: 4 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 4 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement: 4 단계, 이미지 3개 중 3개
      • The protective cover clip is very thin and deforms easily.
      • Remove the single 8mm Torx T10 screw and protective cover clip.
      댓글 쓰기
    5. Sonos One Tweeter Diaphragm Repair/ Replacement: 5 단계, 이미지 2개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 5 단계, 이미지 2개 중 2개
      • Slide the protective cover upwards to remove.
      댓글 쓰기
    1. Sonos One Tweeter Diaphragm Repair/ Replacement, Control Panel & Microphone: 6 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement, Control Panel & Microphone: 6 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement, Control Panel & Microphone: 6 단계, 이미지 3개 중 3개
      • Use the pointed end of a spudger to remove the covers that hide the screws.
      • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
      댓글 쓰기
    2. Sonos One Tweeter Diaphragm Repair/ Replacement: 7 단계, 이미지 2개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 7 단계, 이미지 2개 중 2개
      • With the front of the unit facing you, lift the control panel up using your thumbs.
      • There's a ribbon cable attaching the control panel to the speaker so work slowly.
      댓글 쓰기
    3. Sonos One Tweeter Diaphragm Repair/ Replacement: 8 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 8 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement: 8 단계, 이미지 3개 중 3개
      • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
      • Pull the control panel ribbon cable out of its socket.
      댓글 쓰기
    4. Sonos One Tweeter Diaphragm Repair/ Replacement: 9 단계, 이미지 2개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 9 단계, 이미지 2개 중 2개
      • Pull the control panel away from the speaker to separate.
      댓글 쓰기
    1. Sonos One Tweeter Diaphragm Repair/ Replacement, Power Adapter Receptacle: 10 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement, Power Adapter Receptacle: 10 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement, Power Adapter Receptacle: 10 단계, 이미지 3개 중 3개
      • Remove the six 9mm Torx T8 screws from the motherboard panel.
      댓글 쓰기
    2. Sonos One Tweeter Diaphragm Repair/ Replacement: 11 단계, 이미지 2개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 11 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, separate the motherboard from the speaker.
      댓글 쓰기
    3. Sonos One Tweeter Diaphragm Repair/ Replacement: 12 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 12 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement: 12 단계, 이미지 3개 중 3개
      • Using your thumb, disconnect the speaker cable from the motherboard.
      댓글 쓰기
    4. Sonos One Tweeter Diaphragm Repair/ Replacement: 13 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 13 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement: 13 단계, 이미지 3개 중 3개
      • Disconnect the power adapter plug from the motherboard using your thumb.
      댓글 쓰기
    5. Sonos One Tweeter Diaphragm Repair/ Replacement: 14 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 14 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement: 14 단계, 이미지 3개 중 3개
      • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
      댓글 쓰기
    6. Sonos One Tweeter Diaphragm Repair/ Replacement: 15 단계, 이미지 2개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 15 단계, 이미지 2개 중 2개
      • Remove the motherboard panel from the speaker housing.
      댓글 쓰기
    7. Sonos One Tweeter Diaphragm Repair/ Replacement: 16 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 16 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement: 16 단계, 이미지 3개 중 3개
      • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
      • Remove the two 9mm Torx T8 screws from the power adapter plug.
      • Remove the power adapter receptacle from its housing slot.
      댓글 쓰기
    1. Sonos One Tweeter Diaphragm Repair/ Replacement, Tweeter Diaphragm: 17 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement, Tweeter Diaphragm: 17 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement, Tweeter Diaphragm: 17 단계, 이미지 3개 중 3개
      • Disconnect the woofer cables.
      • If removing the tabs is difficult, the flat end of the spudger may be used to depress the middle tab and then the tab may be pulled to disconnect.
      댓글 쓰기
    2. Sonos One Tweeter Diaphragm Repair/ Replacement: 18 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 18 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement: 18 단계, 이미지 3개 중 3개
      • Disconnect the cables from the tweeter.
      댓글 쓰기
    3. Sonos One Tweeter Diaphragm Repair/ Replacement: 19 단계, 이미지 3개 중 1개 Sonos One Tweeter Diaphragm Repair/ Replacement: 19 단계, 이미지 3개 중 2개 Sonos One Tweeter Diaphragm Repair/ Replacement: 19 단계, 이미지 3개 중 3개
      • Remove the four 10mm Torx T10 screws from the tweeter.
      • Remove the tweeter from the speaker housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Marcus Glowa
회원 가입일: 02/14/18
1,134 평판
안내서 5개를 작성함
USF Tampa, Team S2-G1, Nance Spring 2018 USF Tampa, Team S2-G1, Nance Spring 2018 회원
USFT-NANCE-S18S2G1
3 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 63
전체 시간: 3,938
