주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sonos Playbase Optical Audio Port Replacement
필요한 것
  1. Sonos Playbase Optical Audio Port Replacement, Bottom Panel: 1 단계, 이미지 3개 중 1개 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: 1 단계, 이미지 3개 중 2개 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $79.95
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
    댓글 쓰기
  2. Sonos Playbase Optical Audio Port Replacement: 2 단계, 이미지 2개 중 1개 Sonos Playbase Optical Audio Port Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $79.95
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
    댓글 쓰기
  3. Sonos Playbase Optical Audio Port Replacement: 3 단계, 이미지 2개 중 1개 Sonos Playbase Optical Audio Port Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $79.95
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
    댓글 쓰기
  4. Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: 4 단계, 이미지 2개 중 1개 Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: 4 단계, 이미지 2개 중 2개
    • Unplug the optical audio port from the main circuit board by pinching the white clip and pulling upward.
    댓글 쓰기
  5. Sonos Playbase Optical Audio Port Replacement: 5 단계, 이미지 2개 중 1개 Sonos Playbase Optical Audio Port Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the three 38mm T-55 screws preventing you from removing the Optical Audio Port screws by turning them counterclockwise.
    댓글 쓰기
  6. Sonos Playbase Optical Audio Port Replacement: 6 단계, 이미지 2개 중 1개 Sonos Playbase Optical Audio Port Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $79.95
    • Remove the two 18mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
    댓글 쓰기
  7. Sonos Playbase Optical Audio Port Replacement: 7 단계, 이미지 2개 중 1개 Sonos Playbase Optical Audio Port Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the Optical Audio Port from the housing by pinching the sides and pulling outward.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
James Andrews
회원 가입일: 10/08/18
423 평판
안내서 4개를 작성함
Cal Poly, Team S17-G2, White Fall 2018 Cal Poly, Team S17-G2, White Fall 2018 회원
CPSU-WHITE-F18S17G2
4 회원들
안내서 8개를 작성함
1가이드 댓글
Thank you for this guide, but any idea where to purchase a replacement optical audio port from?
donovanclarkson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 26
전체 시간: 2,944
