주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Alpha 6000 Shutter Button Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
    1. Sony Alpha 6000 Shutter Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Make sure the camera is turned off by turning the switch to OFF.
      댓글 쓰기
    2. Sony Alpha 6000 Shutter Button Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
      댓글 쓰기
    3. Sony Alpha 6000 Shutter Button Replacement: 3 단계, 이미지 1개 중 1개
      • Locate the blue latch that holds the battery in.
      댓글 쓰기
    4. Sony Alpha 6000 Shutter Button Replacement: 4 단계, 이미지 1개 중 1개
      • Push the latch back to release battery.
      댓글 쓰기
    5. Sony Alpha 6000 Shutter Button Replacement: 5 단계, 이미지 1개 중 1개
      • The battery can now be taken out of its compartment.
      댓글 쓰기
    1. Sony Alpha 6000 Shutter Button Replacement, Back Cover: 6 단계, 이미지 1개 중 1개
      • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
      댓글 쓰기
    2. Sony Alpha 6000 Shutter Button Replacement: 7 단계, 이미지 1개 중 1개
      • Turn the camera sideways.
      • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
      • Unscrew using the J00 head screw.
      댓글 쓰기
    3. Sony Alpha 6000 Shutter Button Replacement: 8 단계, 이미지 1개 중 1개
      • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
      댓글 쓰기
    4. Sony Alpha 6000 Shutter Button Replacement: 9 단계, 이미지 1개 중 1개
      • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
      • Locate them and unscrew them.
      댓글 쓰기
    5. Sony Alpha 6000 Shutter Button Replacement: 10 단계, 이미지 2개 중 1개 Sony Alpha 6000 Shutter Button Replacement: 10 단계, 이미지 2개 중 2개
      • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
      • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
      댓글 쓰기
    1. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: 11 단계, 이미지 1개 중 1개
      • Once the back cover is off, locate the flash of the camera and push it forward to open it
      댓글 쓰기
    2. Sony Alpha 6000 Shutter Button Replacement: 12 단계, 이미지 1개 중 1개
      • Locate the two 3 mm screws within the flash and unscrew them
      댓글 쓰기
    3. Sony Alpha 6000 Shutter Button Replacement: 13 단계, 이미지 1개 중 1개
      • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
      댓글 쓰기
    4. Sony Alpha 6000 Shutter Button Replacement: 14 단계, 이미지 2개 중 1개 Sony Alpha 6000 Shutter Button Replacement: 14 단계, 이미지 2개 중 2개
      • Hold the top of the camera away from the body.
      • Carefully turn it over to uncover the bottom of the shutter button.
      댓글 쓰기
    5. Sony Alpha 6000 Shutter Button Replacement: 15 단계, 이미지 1개 중 1개
      • Locate the two screws holding the shutter button and unscrew them.
      댓글 쓰기
    6. Sony Alpha 6000 Shutter Button Replacement: 16 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
      댓글 쓰기
    7. Sony Alpha 6000 Shutter Button Replacement: 17 단계, 이미지 1개 중 1개
      • Turn the top plastic piece back over.
      • Now you will be able to completely remove the camera's shutter button.
      댓글 쓰기
결론
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Fernando Sierra
회원 가입일: 09/30/16
400 평판
안내서 2개를 작성함
USF Tampa, Team 4-5, Passmore Fall 2016 USF Tampa, Team 4-5, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G5
3 회원들
안내서 18개를 작성함
4가이드 댓글
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - 답글 공유
Where can i buy a replacement button?
Simon Lundh - 답글 공유
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster - 답글 공유
Thank you!
Arshad kltn - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 42
지난 30일: 162
전체 시간: 20,094
