주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Alpha DSLR- A850 Focusing Screen Replacement
필요한 것
    1. Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: 1 단계, 이미지 3개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: 1 단계, 이미지 3개 중 2개 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: 1 단계, 이미지 3개 중 3개
      • Push in the button next to the lens.
      • While holding the button twist the lens counter-clockwise.
      • Pull up and remove lens from camera.
      댓글 쓰기
    2. Sony Alpha DSLR- A850 Focusing Screen Replacement: 2 단계, 이미지 3개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 2 단계, 이미지 3개 중 2개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 2 단계, 이미지 3개 중 3개
      • Inside toward the top you will find a small slit in the plastic piece.
      • Insert a flat head screw driver into the slit and pull down to access the focusing screen.
      댓글 쓰기
    3. Sony Alpha DSLR- A850 Focusing Screen Replacement: 3 단계, 이미지 3개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 3 단계, 이미지 3개 중 2개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Using tweezers grab the focusing screen on the side by the two tabs that are on it.
      • Do not grab the focusing screen in the middle as this will damage it.
      • Pull out and remove focusing screen from camera.
      댓글 쓰기
    4. Sony Alpha DSLR- A850 Focusing Screen Replacement: 4 단계, 이미지 3개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 4 단계, 이미지 3개 중 2개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 4 단계, 이미지 3개 중 3개
      • When inserting new screen make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
      • Angle the focusing screen to make installation easier.
      • Lay the new focusing screen into the plastic tray.
      • It does not snap into place.
      댓글 쓰기
    5. Sony Alpha DSLR- A850 Focusing Screen Replacement: 5 단계, 이미지 2개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Insert screw driver into the slit and push up to close.
      • You can also use your thumb, if you are careful not to touch the screen as this could leave a smudge on it.
      • You will hear a click when the plastic tray is back in place.
      댓글 쓰기
    6. Sony Alpha DSLR- A850 Focusing Screen Replacement: 6 단계, 이미지 2개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 6 단계, 이미지 2개 중 2개
      • When re-installing the lens line up the orange dots that are one both lens and camera.
      • Fit lens into place and turn clockwise to secure it back to camera.
      댓글 쓰기
결론
You have now completed a focusing screen replacement.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walter Littlefield
회원 가입일: 03/21/18
286 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 47
전체 시간: 1,421
