주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Alpha NEX-6 Back Case Replacement
필요한 것
    1. Sony Alpha NEX-6 Back Case Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      댓글 쓰기
    2. Sony Alpha NEX-6 Back Case Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      댓글 쓰기
    3. Sony Alpha NEX-6 Back Case Replacement: 3 단계, 이미지 1개 중 1개
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      댓글 쓰기
    1. Sony Alpha NEX-6 Back Case Replacement, Battery compartment screws: 4 단계, 이미지 1개 중 1개
      • Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
      댓글 쓰기
    2. Sony Alpha NEX-6 Back Case Replacement, Bottom screws: 5 단계, 이미지 1개 중 1개
      • Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
      댓글 쓰기
    3. Sony Alpha NEX-6 Back Case Replacement, Side screws: 6 단계, 이미지 1개 중 1개
      • Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
      • Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
      댓글 쓰기
    4. Sony Alpha NEX-6 Back Case Replacement, Dis-attaching procedure: 7 단계, 이미지 2개 중 1개 Sony Alpha NEX-6 Back Case Replacement, Dis-attaching procedure: 7 단계, 이미지 2개 중 2개
      • Starting with the battery compartment gently begin to separate the back case front the camera.
      • Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
      • Gently lift the back case away from the camera an slide it down to completely remove the back case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Clayton Dale
회원 가입일: 01/20/15
1,067 평판
안내서 7개를 작성함
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G2
4 회원들
안내서 63개를 작성함
3가이드 댓글
At {STEP 7} you will notice the last parts to release are the flash button / record button areas. This is particularly tricky.
The flash button release seems to be attached inside, so take care. In my case I did not remove the back case completely due to this.
The corner where the record button is requires extra force to slide down / pry out.
Re-assembly : Take note of these parts.
- the PLAY button flexible circuit has a small hole which fits into a pin on the back case. It is important to align this correctly or your play & AEL button may not function.
- The eye piece has a flexible circuit on its right side which tucks behind a small tab - take care this is not dislodged or it could be damaged when re assembling.
Riquez JP - 답글 공유
Does your team know how to fix the Flash Pop-up button ? It seems the flash for me and others is stuck open and can't be clicked back down. Can you assist ?
rullor - 답글 공유
Can you please let me know how to replace the battery door? Thank you.
Richard Bullough - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 50
전체 시간: 4,739
