주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony BDP-BX320 Motherboard Replacement
필요한 것
    1. Sony BDP-BX320 Motherboard Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
      • Power off and unplug the device from any power source.
      • Place the Blue-ray player on a clean, stable surface.
      댓글 쓰기
    2. Sony BDP-BX320 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Sony BDP-BX320 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Magnetic Project Mat
      $19.95
      • If preferred, use the Magnetic Mat to organize screws.
      • Use a Phillips #1 screwdriver to remove the three 8.3 mm screws on the back of the device.
      • Slide the back section of the top case off the device.
      댓글 쓰기
    3. Sony BDP-BX320 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Sony BDP-BX320 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Sony BDP-BX320 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
      • Use your hands or a metal spudger to gently disconnect the case from the small tabs on the bottom and sides of the device.
      댓글 쓰기
    4. Sony BDP-BX320 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Slide off the front section of the top case to expose the internal components.
      댓글 쓰기
    1. Sony BDP-BX320 Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Sony BDP-BX320 Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Sony BDP-BX320 Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
      • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector located between the two "no fuss" ribbon cables that are attached to the board. This action puts the connector in the unlocked position.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Use tweezers or your fingers to gently pull the cable out of its socket by the blue tab.
      • You may damage the cable by gripping it directly.
      • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
      • Use tweezers or your fingers to pull the remaining four "no-fuss" ribbon cables straight out of their socket to disconnect them.
      댓글 쓰기
    2. Sony BDP-BX320 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Sony BDP-BX320 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the three 7 mm screws that secure the motherboard to the frame of the device.
      • Remove the motherboard from the frame of the device.
      • Be careful when removing the board to disconnect any external ports along the frame's edge that are attached to the motherboard.
      댓글 쓰기
결론
By following these steps, you have successfully replaced the motherboard in your Sony BDP-BX320. To reassemble your device, follow these instructions in reverse order. To test, reconnect the device to power and verify functionality. Avoid overtightening screws and handle components with care to prevent damage.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Diego Vergara
회원 가입일: 09/16/24
165 평판
안내서 1개를 작성함
CSU Los Angeles, Team 5-2, Kershman Fall 2024 CSU Los Angeles, Team 5-2, Kershman Fall 2024 회원
CSULA-KERSHMAN-F24S5G2
6 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 29
전체 시간: 309
